Auto a/c troubles
Old Sep 7, 2011 | 07:28 PM
askingxforxit's Avatar
Auto a/c troubles
No ac, only hot air and only coming from the defrost vents. I can not change direction of air or temperature. I can hear the relay click but no cold air.
Old Sep 7, 2011 | 07:40 PM
Check the FSM and google z32 auto climate control diagnostics. If you need a new control unit, I have one I'll give you. I'm in palm springs.
Old Sep 7, 2011 | 08:18 PM
I've done the diagnostic thing but numbers don't make any sense to me. I can take pics in the morning of what its displaying when in diagnostic mode if that helps.
Old Sep 7, 2011 | 10:46 PM
DuG's Avatar
DuG
Hi
- Are you sure you have frigofluid in the pipes ?
- Compressor can bu running but not compressing if dead
- Is the radiator fan running when you turn on A/C ?
Old Sep 8, 2011 | 12:10 AM
Originally Posted by DuG
Hi
No I haven't been able to check refrigeration fluid or pressure...but yes the fan comes on when I turn on the a/c.
I'm guessing the air is hot because its passing over the heater core due to the fact that I can not change the direction of air flow from the defrost vents.
Old Sep 8, 2011 | 04:58 AM
DuG's Avatar
DuG
You should first check the fluid it's a common issue
then there is no relation with the heater, except if you have another problem like you're heating and freezing at the same time
Old Sep 8, 2011 | 09:29 AM
Ok I'll check the refrigeration fluid when I get a chance then come back when I have more info.
Thanks!
Old Sep 8, 2011 | 12:45 PM
Just a thought, is there a way to electrically test the the ac compressor and or clutch to see if its working??
Old Sep 14, 2011 | 10:27 AM
DuG's Avatar
DuG
I would say you can check voltage for the clutch command first (to know if you have a command from control unit)
but then clutch can be on and the compressor broken
you should control the pressure with compressor working and clutch under voltage to know
excuse my english level :~
Old Sep 14, 2011 | 12:02 PM
maybe u should invest in a set of r134 pressure gauges :/
Old Sep 14, 2011 | 12:06 PM
Would I be testing for voltage at the relay?
Old Sep 14, 2011 | 12:30 PM
DuG's Avatar
DuG
u mean I ?
Old Sep 14, 2011 | 12:31 PM
DuG's Avatar
DuG
meaning you...
DuG's Avatar
DuG
I'm looking for the electrical scheme
Old Sep 14, 2011 | 05:05 PM
Ah lol yes I mean "i" meaning me haha. Thanks!
Old Sep 21, 2011 | 01:09 PM
DuG's Avatar
DuG
got the scheme
mp if you need it
Rootie524
Mar 14, 2012 06:41 PM
ksampara
Jun 24, 2004 05:54 AM
futureZowner
Apr 12, 2004 11:05 AM
Rick280zxt2
Jun 24, 2003 06:37 PM
Beef
Oct 11, 2001 07:39 PM
