Turbo vs high compression setup
Old Feb 16, 2013 | 03:51 PM
emiller009's Avatar
So rebuilding a 1988 z31 n/a when it was suggested to me (by a Chevy guy) to run a higher compression to yield more HP instead of turbo...thoughts are much appreciated.
Old Feb 16, 2013 | 03:59 PM
emiller009's Avatar
Btw first time rebuilding engine learning as I go please be nice
Old Feb 16, 2013 | 04:11 PM
rogerz's Avatar
Grumpy & Helpful
might work on a chevy but doubt running the compression up will get you the same horses as a turbo. you would probably have to put in a magnasquirt to get the fuel mapping right. If you drop in a vg30et you can up the boost to 10psi (which is analogous to going to a higher compression ratio - is that guy still running a v8 with carburetors on it). My 86 works very well with stock components and still beat the honda kids with the 8 inch tailpipes. even suprised a BMW puke yesterday out on the highway. depending on time and money you wish to spend my buddy gets a little over 300hp on his 86
Old Feb 16, 2013 | 04:33 PM
emiller009's Avatar
Peter to avoid motor swap, id like to build the vg30 I have and turbo it as well that was just a suggestion I was curious about
Old Feb 16, 2013 | 04:42 PM
Mycarispurty's Avatar
Turbo the VG30 allllll day long. Forget going high compression n/a on a small little 3 liter.
Old Feb 23, 2013 | 05:32 PM
Flacster's Avatar
Just got vg33et. Best thing you can do with a vg.
Bogdan
Dec 29, 2014 06:35 PM
Randalla
Sep 10, 2008 11:27 AM
foremalaZ
Mar 8, 2005 08:19 PM
Startours7
Jun 25, 2003 07:23 PM
toletero
Feb 27, 2002 04:37 AM
