turbo injectors on na motor??
Old Sep 25, 2012 | 08:36 PM
tatsu's Avatar
so im wondering what would happen if i ran turbo injectors on my NA car, i run pretty rich right now, 13 at idle, at 12.5 above 2500 to 4500, then 12.8 to redline.
so other then running rich, what would happen??
Old Sep 26, 2012 | 07:11 AM
If it's running rich with stock 180cc injectors, what do you think will happen when it's running 260cc injectors?
Eventually it will foul out and die. Running uber rich will usually also contaminate the oil. You could always try it.
Old Sep 26, 2012 | 07:59 AM
tatsu's Avatar
isn't a higher number lean? that's what im always told, so my car is not running rich, at all.
ill probably just get a regulator and bump the pressure up a little
Old Sep 26, 2012 | 08:19 AM
11 is uber rich 17 is uber lean.
Click: Air/Fuel ratios explained (AFR`s) - Subaru Impreza Forum - WRX STI Rally Performance Tuning
Old Sep 26, 2012 | 08:39 AM
ThaPimpShrimp's Avatar
I just want to say thanks for posting this, A/F ratios make a lot more sense to me now!
Old Sep 26, 2012 | 09:08 AM
tatsu's Avatar
And 12 is perfect
Old Oct 1, 2012 | 02:13 PM
AZ-ZBum's Avatar
Run turbo injectors with a turbo ECU.
koprutzxt
Aug 2, 2012 11:55 AM
DUBAUDIO
Feb 1, 2012 07:47 PM
johnsonsz31tt
May 7, 2008 07:27 PM
81s280zx
14
Oct 7, 2005 10:48 AM
piercedZ31N/A
May 18, 2004 10:34 PM
