turbo injectors on na motor??
Subscribe
Sep 25, 2012 | 08:36 PM
so im wondering what would happen if i ran turbo injectors on my NA car, i run pretty rich right now, 13 at idle, at 12.5 above 2500 to 4500, then 12.8 to redline.
so other then running rich, what would happen??
Reply
Sep 26, 2012 | 07:11 AM
If it's running rich with stock 180cc injectors, what do you think will happen when it's running 260cc injectors?
Eventually it will foul out and die. Running uber rich will usually also contaminate the oil. You could always try it.
Reply
Sep 26, 2012 | 07:59 AM
isn't a higher number lean? that's what im always told, so my car is not running rich, at all.
ill probably just get a regulator and bump the pressure up a little
Reply
Sep 26, 2012 | 08:19 AM
Quote: i run pretty rich right now,
Quote: so my car is not running rich, at all.
Quote: 13 at idle, at 12.5 above 2500 to 4500, then 12.8 to redline.
11 is uber rich 17 is uber lean.
Click: Air/Fuel ratios explained (AFR`s) - Subaru Impreza Forum - WRX STI Rally Performance Tuning
Quote: ill probably just get a regulator and bump the pressure up a little
Reply
Sep 26, 2012 | 08:39 AM
I just want to say thanks for posting this, A/F ratios make a lot more sense to me now!
Reply
Sep 26, 2012 | 09:08 AM
And 12 is perfect
Reply
Oct 1, 2012 | 02:13 PM
Run turbo injectors with a turbo ECU.
Reply
