Starting up
Old Sep 23, 2007 | 12:10 PM
Ultimate_300Z's Avatar
Starting up
ok so every mornig i start my car as everyone else but my problem is that when i start it. it tends to not crank right away it kinda clicks for a while then starts up after started it shakes pretty strongly. so i let it idle then it goes away and i drive off. lets say i was to turn it back off and turn it back on. it doesent do it again it just turns right on now my ? is y does it do that could it be my injectors well any advice would help thanks in advance.
Old Sep 23, 2007 | 03:57 PM
my86z's Avatar
weak battery
Old Sep 23, 2007 | 04:31 PM
z-hag's Avatar
Queen of Yachts
and do not forget that you need to run the car for 30 min after you replace the battery for it to get back to real again....makes all kinds of funky sounds sometimes while getting back used to you---i so love these computer managed cars..........
Old Sep 25, 2007 | 07:52 AM
i doubt its the battery cauZe iv already changed the battery a changed a couple months ago
Old Sep 28, 2007 | 06:49 PM
xenonxiii's Avatar
Clean the Battery Cables. Both ends. at the starter you will have Corrosion there.
dustin_ra
Sep 25, 2007 09:48 PM
ZLover4Life
15
Sep 11, 2006 08:21 PM
redlined280
Aug 31, 2006 10:04 PM
Sememmon
May 10, 2006 01:15 PM
beez
Oct 26, 2004 12:27 PM
