need new engine?
Old Feb 11, 2007 | 05:32 PM
Comrade_Charlie's Avatar
need new engine?
My engine recently started ticking bad, cousin says lifters... my car has 247K on the stock turbo engine. There is a 88 non turbo engine with 180k for 200 bucks at a junkyard that just was pulled in, yall think it would be worth it. my Friends 86 Supra started doing the same thing and threw a piston a day later so... I wonder if the compression would get in the way of having around 10psi of boost... or should I just take my motor apart. But I would really just like to swap it and run that one till I have some real money for cams and real upgrades.
Old Feb 11, 2007 | 06:15 PM
Might want to find out the problem before buying a new engine...
Old Feb 11, 2007 | 06:47 PM
agreed^^^ but if you do get a new engine... why would you get a non turbo when you are turbo???
Old Feb 12, 2007 | 02:05 PM
Because I cant buy a turbo engine for 200 bucks. My friend has a good running vg30e that he is swaping a turbo engine into maybe I can get that... My cousins non turbo started with this noise then blew up. I think for now im just going to ride it till it dies unless I decide to rebuild it. I also wanted a new motor because this one has 247k, but I guess ill ride it till it dies or I rebuild it, I just dont want it to break at a time when im low on cash...
300zgearhead
May 6, 2010 11:45 AM
smokingzcar
Dec 5, 2002 07:57 AM
