mods question
Old Oct 1, 2006 | 07:25 PM
Turbo86's Avatar
mods question
if I get a 3" cert muff turbo back exhaust, cone type air filter (apexi), l&p performance intake manifold, 240sx 60mm TB, and a boost controller set at about 10psi ... what kind of 0-60, 1/4 mile, rwhp and or fly wheel hp am I gonna have on a 1986 turbo z31
Old Oct 2, 2006 | 12:21 AM
emo236's Avatar
confuzed member
people always ask these questions and there's no answer to them! It depends on the condition of your engine, air leaks, etc. There's SOOOOO many variables there's really no good answer.
Old Oct 2, 2006 | 06:08 AM
Turbo86's Avatar
just a ballpark dude ... my car only has 62,000 miles its in fantastic shape
Old Oct 2, 2006 | 07:34 AM
To rest your mind...
Stock 86 turbo had about 200 flywheel hp @ 6.7psi.
Your 86T:
- 10psi boost: +20hp
- 3" exhaust: +2 to 4hp
- Cone filter: +1 to 3hp
- Performance intake manifold (REALLY DEPENDS ON QUALITY): 0 to +10hp
- 60mm TB (benefit only if used w/ performance intake... it's been proven to make no difference on the stock Z31 manifold). On performance intake: +2 to 4hp
I believe the stock 0-60 time is around 6.5sec & the quarter mile in the high 15's and in the ~85mph trap speed. At 10psi, you should be able to get into the low 15's or high 14's & in the 90mph range.
These are just rough estimates, so take em or leave em. You'd be wise to get an INTERCOOLER as well.
Old Oct 2, 2006 | 08:22 AM
Turbo86's Avatar
how hard is it to swap out a turbo on a scale to 1-10 ... i've done a timing belt 60,000 job and that was a big pain in the butt the first time doing it, now I could prob do it in a day with no probs
Old Oct 2, 2006 | 08:28 AM
Is your turbo dead?
Old Oct 2, 2006 | 08:30 AM
Turbo86's Avatar
nope it's good ... just want to get a better turbo t3/t4 ect.. for more power
Old Oct 2, 2006 | 10:37 AM
emo236's Avatar
confuzed member
bolt out and bolt in. Turbo's are easy to swap. Take off the intake, unbolt the turbo from the downpipe, unbolt from the exhaust manifold. Unbolt the oil lines and air lines and you should be out. To put a new one in, the same procedure backwards. You may need a different flange to fit a bigger turbo on though, so look into that. And 2nd. Get an intercooler.
ZUL8R
May 1, 2013 07:30 PM
ViperGTO99
Jun 20, 2007 07:50 PM
stealth300Z
Mar 29, 2003 09:22 PM
4rdhater
Nov 22, 2002 04:53 PM
n3i0s0sZaXn
Sep 9, 2002 09:08 PM
