manual transmission
Old May 8, 2002 | 08:17 PM
ZenArcher's Avatar
Re: manual transmission
Jack it up in front. Crawl under. Locate transmission. You will see a drain hole and a chck/fill hole.
ZenArcher
Old May 9, 2002 | 09:34 PM
ZenArcher's Avatar
There is a fill hole a few inches above the drain hole. I'd suggest buying a hand pump to refill. I've tried the funnel and long tube way and it doesn't work well.
ZenArcher
Old May 11, 2002 | 06:10 AM
Spot's Avatar
if you get the kind that comes in a bottle with a pointed nozzle, then you can force the long tube onto it and squeeze the oil into the tube and down into the tranny. they also make these fillers that are a tube with a fitting on the end that you screw onto the bottle you are filling. the tube is only about 16" long though, I replaced that tube with a longer one and filled it from the top of the engine. That seemed to work pretty well. the fitting fit's the bottle tight enough that you can squeeze the bottle, otherwise it would take all day for it to fill the tranny.
ZXGrinch
Dec 12, 2011 01:46 PM
KNBIKER
Mar 28, 2009 01:05 PM
74260zt
Feb 24, 2008 07:32 AM
74260zt
Feb 23, 2008 06:30 PM
kansaskeith
Dec 23, 2003 02:12 PM
