Hard Start When Cold
Old Feb 8, 2018 | 06:55 PM
deonw1's Avatar
Question Hard Start When Cold
So, I have an 85 Z31 N/A that has a difficult time starting when cold. If I let the fuel pump prime a few times before starting or use starting fluid she will fire right up. She will also stay running and restart without any issue for the rest of the day. I have installed a new fuel pump, and FPR, checked the fuel pressure, spark, vacuum, and the ECU is clear. Everything seems to check out as per the FSM. The only strange thing I see is the FSM has 2 different configurations for the FPR fuel hose routing, one for turbo and the other for N/A. I have an N/A that appears to be routed like a turbo. Any input would be greatly appreciated. Thanks
Old Feb 14, 2018 | 07:01 AM
Welcome to ZDriver! So when you check fuel pressure, what's it at? Did you do a leak down test?
Old Feb 15, 2018 | 02:02 AM
87moonglow's Avatar
Hey everyone, and to op, sorry this is diff from what u guys are talking about but have u changed the thermostat or is it even still there?
Old Feb 15, 2018 | 05:54 AM
deonw1's Avatar
When it first primes the pressure is at 34 psi and after starting ~25 - 26 psi. And yes, I did a leak down test, but I forgot the exact time frame it took for the pressure to bleed down, but it took over an hour. I may have to do the bleed down test again to get you a more accurate answer. I read on post that someone had a similar issue and removed the fuel return line and it help. Possibly some blockage in the return line? Thanks again for your help.
Old Feb 15, 2018 | 05:58 AM
deonw1's Avatar
No , I haven't changed the thermostat, yes it is still there and working as far as I can tell. So what's your theory?
Old Feb 16, 2018 | 01:45 AM
87moonglow's Avatar
It would generally take longer for the car to warm up, and now that I rethink that, it would only effect the coldstarts after the engine has been running, Im not positive though about the latter tho. Another brainstorm would be the MAF/ throttle body being dirty (maybe IDK) iv cleaned mine before and it helped my idle/coldstarts slightly
bongpogi
Aug 19, 2015 11:15 AM
Treacy
Nov 14, 2013 11:23 AM
HybridS130
Dec 5, 2005 04:59 PM
Wolfe
Dec 24, 2001 09:55 PM
