gas ? and burning oil?
Old Jan 11, 2006 | 12:54 PM
91Zman's Avatar
Opinionated
First question, what octane fuel do you guys put in your Z? Second, i think my car is burning oil, my chrome exhaust tip is black and i touched it and its sticky. My oil dip stick is above H, could that be the problem?
Old Jan 11, 2006 | 01:02 PM
AZ-ZBum's Avatar
if it's stock, all you need is 87 octane.
Old Jan 11, 2006 | 01:08 PM
Fast240Z's Avatar
Be careful with your oil over the full mark, you could blow gaskets and seals, etc.
Old Jan 11, 2006 | 01:47 PM
91Zman's Avatar
Opinionated
Anyone have ideas on my exaust issue?
Old Jan 11, 2006 | 01:52 PM
WolfMan's Avatar
the exhaust issue... Well my Z does not have that problem, maybe you already blew a seal because of to much oil? Get it pressure checked for leaks, and drain the oil to check for foreign fluids. Also, I dont think it is oil out the back, well, what kinda exhaust? Because thats an pretty long distance for oil.
PS Keep the oil in the middle!!!!! its a old car man
Old Jan 11, 2006 | 03:45 PM
91Zman's Avatar
Opinionated
i have flow masters
Old Jan 12, 2006 | 11:05 AM
WolfMan's Avatar
nice, did you check for leaks? and another thing you could prolly due is check for compression, maybe your rings are worn out? also did you take it to a shop and pressure check it?
Old Jan 12, 2006 | 08:29 PM
91Zman's Avatar
Opinionated
About how much does it cost to get it pressure checked and/or have the piston rings replaced (a general estimate so if i go to get it done i don't get ripped off)
Old Jan 13, 2006 | 08:15 AM
Fast240Z's Avatar
you could get a shop to do a leakdown test for under $100
Old Jan 13, 2006 | 08:55 AM
91Zman's Avatar
Opinionated
Can you explain to me what they do?
ABout how much would piston rings be?
Old Jan 13, 2006 | 12:05 PM
WolfMan's Avatar
they are just going to put pressure into your system, and if it does not hold the pressure that means there is a leak, and a set of rings I don't know, check parts america or summit, parts america will give you the cheapest/ prolly low qual, and summit will give you the better ones and thier price
good luck
Old Jan 13, 2006 | 01:00 PM
91Zman's Avatar
Opinionated
good luck
thanks. My oil is High, just as i thought. Tommorow im changing my oil, how many Quarts do i need. 4 if im correct?
Old Jan 14, 2006 | 07:11 AM
WolfMan's Avatar
4 and 1/4 if I remember correctly, I just dump 4 in, then drive a block, and let it sit. Then I proceed to top it off
Old Jan 16, 2006 | 09:17 PM
pete8717's Avatar
I run 89 octane with an STP octane booster. I don't know how much that raises the octane level but I definitely notice the difference if it's less than 89. I had my brother fill my 300zx up while i was putting air in the tires and he put in 85 octane and it ran like ****. As for the piston rings, I've always said doing it yourself is the fun part... I tested the compression on my 300zx on a 40 degree day and I was pushin about 160...I think psi...whatever the pressure tester was measured in...I don't remember.
Old Jan 17, 2006 | 03:52 PM
91Zman's Avatar
Opinionated
Did my oil change today, 4 quarts, car runs alot smoother now....i think the high oil was the cause to alot of my problems (Jerky acceleration, ect ect). Hopefully tommorow morning when i go to school ill find out for sure if its running smoother (i only drove it around 2 blocks tonight). Last time i had 4 Quarts of oil + 1 quart of engine treatment
Old Jan 21, 2006 | 02:57 AM
AZ-ZBum's Avatar
You're wasting money. But hey! If it makes you happy, go for it.
No stock Z31 requires more than 87 octane. Running a higher octane than required can and will cause other problems.
thekid
Apr 21, 2013 09:31 PM
NismoPick
Sep 21, 2009 09:00 AM
81-280zxnt
Sep 9, 2009 07:10 AM
Craig_Paterson
14
Mar 7, 2005 02:47 PM
2000SR20
Oct 16, 2002 05:28 PM
