The fan behind the head light only turns on when the key is all the way off.
Old Jul 5, 2011 | 08:39 PM
Beaneriser's Avatar
The fan behind the head light only turns on when the key is all the way off. If you put the key in any other position it turns off...I have to unplug it to make it turn off, and i won't turn on at all when the car is on. could it be a reversed wire or something simple hope fully?
Old Jul 6, 2011 | 02:20 AM
Flacster's Avatar
Are you talking about the injector cooling fan?
Old Jul 6, 2011 | 09:06 AM
Beaneriser's Avatar
i believe so, the blower fan that is behind the driver side head light, and has the port leading to right above the fan shroud.
Old Jul 6, 2011 | 09:46 AM
Flacster's Avatar
Yup thats the injector cooling fan. It's not big deal. I hear a lot of z owners remove them.
Old Jul 6, 2011 | 09:54 AM
Is your motor getting hot (temp gauge going over half way)? I'm sure the Z31 injector fan is programmed in a similar way to the 280zx... if the coolant gets above something like ~220* at any time when the motor is running, once the car is turned off, the injector fan will come on for 17 minutes.
Old Jul 6, 2011 | 02:30 PM
Beaneriser's Avatar
huh that makes sense i need a new radiator the temp stays a little more than half...thanx
Pipsqueak
Mar 13, 2013 10:52 AM
ricky0288
May 27, 2011 10:07 PM
straight hate
Sep 6, 2006 10:04 AM
nka04a
Mar 18, 2005 04:00 PM
fuzzo
Sep 13, 2003 07:30 PM
