engine problems
Old May 5, 2005 | 08:05 PM
sk8er_of_durand's Avatar
engine problems
i have a 87 non turbo with 177000 miles on it. it just started smoking after i put some oil in it. i cant seem to figure out why. can anyone help me?
Old May 5, 2005 | 08:53 PM
zcar300zx's Avatar
what color is the oil????and how much did you fill??
Old May 5, 2005 | 08:59 PM
zcar300zx's Avatar
I MEAN....what color is the smoke lol
Old May 5, 2005 | 10:53 PM
86zxt(954)'s Avatar
u soaked the valves...
Old May 6, 2005 | 09:00 PM
zcar300zx's Avatar
like i said....WHAT COLOR IS THE SMOKE...dont just jump to conclusions..there are many different ways for a car to burn oil..and leaking valve guides/seals is not the only way to do it
Old May 6, 2005 | 09:46 PM
color of smoke an color of oil
The smoke it white with gray. The color of the oil is a dark brown.
Old May 6, 2005 | 09:47 PM
i only added 2 qrts
Old May 6, 2005 | 10:27 PM
zcar300zx's Avatar
k well...burning OIL is a blueish hue...white means coolant and black = gas...so if it is sortof a blueishi whitish color than yes be thinking oil... Too high an oil level in the crankcase will let the crankshaft churn the oil to foam. This will result in oil pump starvation, which means your engine won't be properly lubricated. Overfilling can also lead to high crankcase pressure, possibly leading to oil seal leaks. meaning yes the valve guide/seals oil rings on the pistons...either way..DAMMMMIT
Old May 7, 2005 | 01:08 AM
86zxt(954)'s Avatar
told u....
Old May 7, 2005 | 06:36 AM
Fast240Z's Avatar
does it smoke at startup, or anytime you drive it?
Old May 7, 2005 | 11:08 AM
zcar300zx's Avatar
good point fast, good question
Old May 7, 2005 | 11:10 AM
zcar300zx's Avatar
does it smoke on startup or acceleration or deceleration is the question?
Old May 7, 2005 | 02:01 PM
Fast240Z's Avatar
if it smokes only at startup, there's a good chance that your valve guides are bad. If it smokes all the time, then there is a good chance that you are getting some blow by from the piston rings.
Old May 7, 2005 | 10:39 PM
zcar300zx's Avatar
agreed...doesnt seem hes too interested tho lol
Old May 8, 2005 | 12:46 PM
smoke when i drive
it doesnt somke until i start to driving for about 5 minutes then it smokes
Old May 8, 2005 | 12:48 PM
Fast240Z's Avatar
sounds like blow by from the rings, which isn't a good thing. If it is, then you're going to have to replace your piston rings, which is alot of labor.
Old May 8, 2005 | 08:33 PM
zcar300zx's Avatar
for sure...or alot of cash lost depending on if youre a backyard warrior or a let someone else do the job sorta guy
Old May 10, 2005 | 02:43 PM
how much are piston ring
how much are piston ring and does any one know of any one selling a 300zx motor complete only or just some piston rings
Old May 10, 2005 | 09:32 PM
zcar300zx's Avatar
try zcarparts.com... or checker lol....anywhere sells rings...just a matter of labor
Old May 13, 2005 | 11:47 PM
madness's Avatar
engine
u can get a used engine for 600 to 800 thats block and heads only u will need to switch over everything else. most places offer decent shipping rates and a warranty. i have only found one complete motor and it was 87 turbo for 900 and 200 to ship.
mad scientist
Dec 9, 2011 10:32 PM
MellowYellow300
38
Oct 24, 2006 03:41 PM
pinkneyss
Mar 30, 2006 06:46 AM
MarkieMark
Aug 29, 2005 05:54 PM
Z_For_Life
Aug 29, 2002 09:02 AM
