engine knock
Old Jun 11, 2013 | 12:56 PM
soates4's Avatar
engine knock
my car was missing so i decided to clean my maf. i took it out and cleaned it. then put it back in. after i let it dry. i also changed my spark plugs. after everything was put back together i fired it up. and the engine started knocking bad. does anyone know what this means? thanks
Old Jun 11, 2013 | 01:25 PM
If you mean knocking like "knocking and pinging", check your timing. What octane are you using? Turbo or n/a engine? Also check ecu codes.
If you mean knocking like "metal on metal", then it could be a cam / valve train problem, or a rod knock.
Video clip?
Old Jun 16, 2013 | 01:07 PM
AZ-ZBum's Avatar
You dropped something into the cylinders when you changed your spark plugs. Now you'll have to remove the heads.
93xZX
Jul 10, 2016 09:58 AM
tvanaukenz31
Jan 8, 2013 07:07 PM
jorge9473
Sep 2, 2012 12:34 PM
zcrazy13
Aug 1, 2011 05:36 PM
tsefreeflow
Sep 21, 2003 02:29 AM
