86 z31 turbo with boost problem :(
Old May 16, 2011 | 02:07 AM
86_VG30ET_Z31's Avatar
I just had my 3" exhaust done an a 2.5" intercooler but i notice dat i wasnt boosting my gauge read 0 lbs an if i shift into higher gear an floor it the boost will go up to 4lbs an then start droppin till it hits 0 again i did a leak test on the intercooler setup an it hold more than 20lbs without a leak any suggestions on what the problem maybe thank you for all the help.
Old May 16, 2011 | 08:46 AM
Check the hoses to the waste gate. Are you using a boost controller?
Old May 16, 2011 | 11:19 AM
AZ-ZBum's Avatar
Boost leak. Make sure everything is connected and not coming apart.
Old May 16, 2011 | 03:14 PM
All the hoses are tight as they could be an i did a leak test and it hold the air well without a leak an im not running a boost controller just stock boost could it be the wastegate actuator
Old May 16, 2011 | 03:23 PM
Also be sure to measure the boost on a real boost gauge and not the stock one.
Old May 16, 2011 | 04:52 PM
Its not the stock gauge its an aftermarket
Old May 16, 2011 | 05:11 PM
omniserv's Avatar
It sounds like you know what you are doing or you wouldn't have added a intercooler.
Makes me wonder if something got sucked into the turbo? You had a lot of new parts that could have had something in them. Packaging peanuts, tape, paper etc. Maybe something soft enough to only drag the turbine down but not stop it.
Old May 16, 2011 | 06:39 PM
AZ-ZBum's Avatar
He's running an intercooled setup on stock boost.
I'm thinking a hose is ripped or not connected properly.
Question: How did you do a leak test?
Old May 17, 2011 | 01:22 AM
I removed the coupler that conect to the throtle body an plugg it with a pvc drain pipe an on the side of tHe turbo another plug with a gauge to measure air presure an i put 20lbs an checked all couplers with soap an no leaks at all i let the air sit for about 5 mins an only about 2lbs dropped
Old May 17, 2011 | 01:35 PM
AZ-ZBum's Avatar
Yep. Does make it seem to lean more towards the wastegate.
Old May 17, 2011 | 01:47 PM
How can i test the wategate actuator
Old Jun 3, 2011 | 02:26 AM
Wastegate replaced an still no luck the only bad thing i could think of but dont knoe if its whats causin my problem is an exhaust leak on the left side manifold the gasket is out an it leaks alot i will change it but i was wondering if dat had anything to do with my problem thank you
Old Oct 24, 2011 | 12:55 PM
Z31Turboed's Avatar
Probably. Depends on the size of the leak.
Did you replace the Wastegate itself, or just the wastegate Actuator ? (or both)
VanBruno
Nov 2, 2014 10:16 PM
Clutch89
Sep 29, 2013 07:54 AM
jaredjmoore89
19
Jan 13, 2008 04:11 PM
wc_dallas
May 2, 2005 11:08 AM
joeyZrazer
Jun 14, 2002 06:31 PM
