85T Auto, Transmission noise
Old Nov 27, 2013 | 02:12 PM
mellor21's Avatar
When I let off the throttle, my transmission makes a weird noise. Like a really fast papapapapa or tha tha tha tha, it's hard to describe. I believe that it's the tranny because it seems the sound is coming from directly below the center console. Could it be the catalytic converter?
This is the only car I've ever owned with an automatic transmission and I honestly don't know a lot about them. I've replaced the head gaskets, timing chain, and done a lot of other little things on this car so I'm not completely mechanically inept.
Any ideas? My transmission fluid looks fine.
Edit, it only does this while the car is moving, not if I rev it up in park or neutral.
Old Dec 21, 2013 | 09:37 PM
reddzx's Avatar
Most likely the rear transmission mount. When the rubber deteriorates, it's metal to metal on the chassis and the noise comes right up through the console and sounds like the trans going out.
Old Dec 22, 2013 | 12:55 AM
rogerz's Avatar
Grumpy & Helpful
if you replaced the timing chain you are driving a z with an l28 engine. at least learn the correct terminology when you speak
Old Dec 24, 2013 | 02:09 PM
mellor21's Avatar
Thanks a ton reddzx!
I did the belt 5 years ago, sorry it slipped my mind that it wasn't a chain.
carlos48
Feb 2, 2014 09:31 AM
zfreak1981
Apr 13, 2009 04:15 PM
ZThirtyOne
Feb 19, 2009 08:43 PM
dsiggy
Jun 9, 2002 07:35 PM
Wolfe
Dec 2, 2001 04:01 PM
