transmission noise
Old Apr 6, 2009 | 04:11 PM
zfreak1981's Avatar
transmission noise
My 1983 280zx non turbo 5 speed is making a noise when the clutch is out. But when I push the clutch in, it stops. So I replaced the clutch the throw out bearing and the pilot bearing and it still makes the noise. I can hear it when im driving it also. Any ideas? thx
Old Apr 6, 2009 | 04:27 PM
icice9's Avatar
Super Siver & Black Stud
i would have guessed it was your throw out bearing but you said you changed it.. when you installed it on the yolk did you use a press?
Old Apr 6, 2009 | 05:24 PM
zfreak1981's Avatar
tranny
nope, didnt need a press. just slid on and put the retainer clip back in.
Old Apr 6, 2009 | 08:07 PM
sure you got that clip on the T/O bearing right? if not, i could only venture its a bearing in the tranny itself. you sure its coming from the tranny? the noise?
Old Apr 6, 2009 | 08:35 PM
zfreak1981's Avatar
tranny
Im ot to sure. It kinda sounds like it could be coming from the gear box as well
Old Apr 6, 2009 | 09:03 PM
tranny and gear box be the same thing. lol. unless your referring to just inside the bell housing leaving it open only to the clutch setup. but there's bearings all the way up front there to that support the shafts inside the tranny that could go bad.
Old Apr 7, 2009 | 05:02 AM
zfreak1981's Avatar
tranny
understood. Im just thinking that it could be something in the gears that could be worn other than the pilot and the throw out bearing.
Old Apr 10, 2009 | 09:39 PM
PooFlinginMonke's Avatar
Input or countershaft bearings.
Many nissan trannies will run for 10,000 miles or more making that noise........but not all of them.
When you drained the oil, did any ball bearings or the cages fall out?
Old Apr 13, 2009 | 04:15 PM
zfreak1981's Avatar
tranny
very good possibility. but nothing came out when drained.
mellor21
Dec 24, 2013 02:09 PM
Flacster
Oct 20, 2010 07:34 PM
ZThirtyOne
Feb 19, 2009 08:43 PM
79bigbore280zx
Oct 27, 2003 10:36 AM
SwiggA88zxt
Apr 23, 2002 03:15 PM
