1986 z31 turbo ac condenser fan
Old Aug 31, 2015 | 12:00 PM
Mike Kwon's Avatar
any members been thru fixing ac condenser fan?
here is what i have checked so far.
1. fuse is ok
2. relay is ok
3. water tem switch is ok
4. ground at condenser fan motor is ok
5. fan motor is workinf ok (direct 12 volt supplied)
6. found open wire from relay to fan motor connector.
7. found open wire from water temp switch to relay.
should i just connect fan motor direct to ac compressor clutch?
my z was getting hot one day with ac on (outside temp was 103).
if i turn the ac off then engine temp drop to normal.
i was thinking because of malfunction of ac condenser fan cause the over heating problem.
any body had this symptom to your turbo z (mine is 1986)
help need it here .
thanks for reading.
mike
Old Aug 31, 2015 | 12:45 PM
I would start with fixing these two wires.
Old Sep 2, 2015 | 03:17 PM
Zuphoria's Avatar
That fan will only kick on when you car reaches a super hot temp. Ive only seen mine come on like once, but i do alot of night driving.
Old Sep 14, 2015 | 02:42 PM
Mike Kwon's Avatar
replaced all the wiring for the ac fan.
and also replaced the ac condenser switch.
and the fan kicks in with when temp reaches 210 or 22o with the ac on.
Old Sep 14, 2015 | 04:09 PM
Zuphoria's Avatar
so you fixed it?
Old Sep 14, 2015 | 04:35 PM
Mike Kwon's Avatar
Yes it's fix and works fine now.
I can ac condenser fan kicks in.
TigroGT
Oct 20, 2014 06:33 PM
Spurs212095
Jun 5, 2012 10:02 AM
z_man365
Jan 16, 2012 09:11 AM
83Turbo
May 19, 2010 05:37 PM
MR300ZX909
Jun 9, 2004 12:49 PM
