is it worth fixing
Old Jan 22, 2012 | 12:32 PM
mossyoak.1988's Avatar
is it worth fixing
well i got a 86 300zx turbo 5spd. it has 150k miles and last week the fuel pump went out and the fuel pressure regulator started to leak. also it backfired and blew out the maf sensor. it it even worth fixing bein 25 yr old daily driver.
Old Jan 22, 2012 | 12:48 PM
It's up to you... do you WANT to fix it?
Those things are cake... don't be so emo.
Old Jan 22, 2012 | 10:12 PM
alright well i was gonna pull the maf sensor but there are 4 bolts holding it on i can get to the tow on the left but the ones on the right i cant seem to get and also there is a deal in the back of the car with two screws in it is that for the pump or do i have to drop the tank
Old Jan 23, 2012 | 08:56 AM
Time to look in the FSM you downloaded from xenonz31.
The MAF is seriously easy to get out... just gotta remove a few things to get your ratchet down to the bracket bolts.
As for the "deal" in the back... gotta be more specific. There are lots of "deals" in every car. Open FSM... look up efi / fuel pump / fuel tank section... read.
Old Jan 23, 2012 | 12:52 PM
Yavin's Avatar
The Deal in the back is not to pull the fuel pump. The sending unit will be underneath that one. You will have to drop the tank to replace the fuel pump. Call Steve at www.300zxpartsforyou.com about the fuel pump. He has used pumps for in the $80 range. Be careful removing the sending unit as the solder joints on the wires of mine were pretty bad and actually fell off.
I would recommend dropping the tank, clean the tank really well and allow to dry a day or two since you have it off and replace the fuel pump. It is not hard but you will need an extra set of hands and an hour or so once the fuel is out of the tank.
Old Jan 23, 2012 | 12:57 PM
Yavin's Avatar
Plus, all those parts are only about $200 used from steve. It is definitely worth $200 to fix.
Old Jan 24, 2012 | 12:02 PM
AZ-ZBum's Avatar
Don't buy a used fuel pump for $80 when you can buy a new one for $100.
To replace the fuel pump, you HAVE to drop the tank.
But if you're having an issue getting your MAF out of the car, then I'm not sure how capable you are with this repair.
Old Jan 24, 2012 | 12:15 PM
Yavin's Avatar
Yup. If you can get a new one for $100 do that for sure. I couldn't find one that cheap when I was looking and I also needed the entire housing since mine was pretty bashed up from a previous owners "repair".
Old Jan 24, 2012 | 05:15 PM
AZ-ZBum's Avatar
These are the instructions I used when I replaced mine.
Old Jan 24, 2012 | 11:36 PM
alright well i got it all figured out and i found a guy who is parting out a 86 n/a and i got the maf and the whole pump unit for 70 bucks thought it was a good deal the car only had 90k and im buyin the pressure regulator new i dont trust a used one bein that they will be 25yrs old like mine
nd_track_driver
Feb 22, 2009 11:59 AM
hoov100
Mar 18, 2006 09:42 AM
junk280z
Feb 14, 2006 12:48 PM
Fast240Z
May 13, 2005 11:04 AM
Yuichi
May 6, 2001 06:53 AM
