Fixing Rusty Floorpans
Old May 12, 2005 | 01:38 PM
Fast240Z's Avatar
What would be the easiest way to fix some rusty floorpans? Mine are good, except for a few spots here and there that need to be cut out and replaced. Someone was telling me that you can not weld new metal to floorpans, or something like that, so how would I fill these holes? I have a wire feed welder (Ingersoll/Rand, I believe), and my father used to weld for a living, so the welding isn't an issue.
Old May 12, 2005 | 01:54 PM
theramz's Avatar
I have a present for you...
The problem is the thick coating of tar they put over the floorpans inside and out. If you can get it cleaned off, I don't see why a wire feed welder couldn't do it.
Old May 12, 2005 | 02:16 PM
Fast240Z's Avatar
it shouldn't be too hard to get the tar off. I should be able to scrape it off, or weld the piece in from the inside of the car. Worst case scenario would be that I could just heat it up with the torch that we have and melt the tar off somewhat.Would regular sheet metal work?
Old May 12, 2005 | 03:19 PM
theramz's Avatar
Yeah, I think 20 gauge will work ok. Then you can put some new under sealer on it.
Old May 13, 2005 | 11:04 AM
texasz's Avatar
STOP THE PRESSES!!!! First the tar mat is on the inside of the car. Second, that stuff is hard to remove! Heating it up you will just end up with a big bubbley mess of tar goo. I'll post a link to the best solution to removing that stuff later.
EDIT: here's the link: http://www.classiczcars.com/forums/s...ad.php?t=16546
Demi Colwell
Nov 4, 2013 11:56 AM
Male
Jun 16, 2012 11:08 AM
slammed87d21
14
Jun 6, 2008 02:21 AM
raythenegr0
Jun 2, 2008 12:02 PM
junior
Oct 8, 2002 11:49 AM
