Where's the stupid sensors???
Old Aug 14, 2007 | 05:08 AM
Heat Rave R's Avatar
For the life of me, I just can't find the knock sensor and exhaust gas temp sensor on the Z31 Turbo. Can someone please help me?
I was under the impression the knock sensor was on the right side of the head and the exhaust gas temp sensor was near the EGR. But all I could find was some small "thermal sender" on the right side of the head (pictured on the left), and some unknown sensor on the left side of the engine. What does that "thermal sender" do? And is that sensor on the left side actually the knock sensor (if it is, does anyone know what size socket to bring)? And where is the exhaust gas temp sensor?
If anyone could provide some pictures of where these sensors are located, I'd be eternally grateful.
Attached Thumbnails Where's the stupid sensors???-sspx0083.jpg   Where's the stupid sensors???-sspx0084.jpg
Old Aug 14, 2007 | 07:44 AM
I'm pretty sure there is no EGT on the Z31 from the factory.
Old Aug 14, 2007 | 09:53 AM
EZDUZIT's Avatar
East Coast Style
The Knock sensor is located on the passenger side of the block right behind the Motor mount. We do not have EGT sensors.
1st pic: This is your head temp sensor
2nd pic: This is the temp sensor for the cooling fan
Old Aug 14, 2007 | 01:19 PM
The EGT sensor is apparently a CA-only sensor, probably due to the stricter emissions.
Old Aug 14, 2007 | 01:23 PM
Is that location accessible from the top of the engine bay, or will I have to go under the car? How much removing of surrounding stuff will I need to do in order to reach it?
Old Aug 14, 2007 | 01:37 PM
all the z31's around here only have o2's
Old Aug 14, 2007 | 01:52 PM
Well hot diggidy... there is a CA version w/ EGT:
http://www.redz31.com/pages/fuel.html
CALifornia and FEDeral ECU’s can interchange. The only known physical difference in the CAL version is the presence of an EGT sensor.
Old Aug 14, 2007 | 01:59 PM
must be a 88-89 thing..
Old Aug 14, 2007 | 05:06 PM
inqui-Z-tor's Avatar
FSM shows EGT on 84 NA and Turbo models too ..
Old Aug 15, 2007 | 12:33 AM
So now that it's been established CA Z31's have an EGT sensor, does anyone know where it is? ^^
Old Aug 15, 2007 | 06:15 AM
Check your FSM .. EF & EC pages (4 and 5 in the 84 FSM) .. shows the EGS located just before the CAT ...
Old Aug 15, 2007 | 08:44 AM
AZ-ZBum's Avatar
Pic 1: Temp sensor for the instrument cluster.
Pic 2: Temp sensor for the injector cooling fan.
Silver valve covers indicate you have an NA motor, so there would be no knock sensor.
Old Aug 15, 2007 | 10:27 AM
i have yet too see a EGT sensor on any CAL spec z31's..
Old Aug 17, 2007 | 10:26 AM
PooFlinginMonke's Avatar
California Z cars going back to the 70s usually had equipment not seen on federal spec cars.
drummer69
May 30, 2006 07:33 PM
81 Black L28E
Oct 6, 2005 06:54 PM
Brewster
May 1, 2005 10:05 PM
tt300z
Jan 16, 2005 09:43 PM
tenjin
Apr 19, 2003 09:43 AM
