water temp gauge
Old Sep 18, 2014 | 11:27 AM
cbernone's Avatar
water temp gauge
Water temp gauge not working, new sensor, full coolant. Can't explain it. What's up?
Old Sep 18, 2014 | 12:34 PM
zxguy1986's Avatar
You checked all your fuses... Sounds like you have to check the continuity of the circuit from the sensor to the gauge - to rule out the gauge itself. If the circuit is good, it's the gauge - or yor 'new' sensor. Gotta get out your tester - or buy/borrow one.
You will find the detailed electrical diagrams to trace - and maps locating all the connectors for you - in your factory service manual (FSM free at XenonZ31 Reference ) Takes a while to access the connectors but the wire colors are typically consistent all the way through - so that's good. Take your time. You'll figure it out.
Before you begin, tap the face of the gauge a little to see if your needle is just stuck at zero and frees itself. Stuff happens.
Old Sep 18, 2014 | 04:17 PM
rogerz's Avatar
Grumpy & Helpful
turn on ignition. have someone watch the temp gage or rig a mirror so you can see it. remove the wire from the sensor and ground it. the gage should pin out. if not you need to find continuity from gage to sensor. also see if gage has power going to it.
Old Sep 19, 2014 | 06:21 AM
Zuphoria's Avatar
Ive had the gauges go bad in 2 of my z31s. just go to the junkyard and get a cluster
Old Sep 19, 2014 | 06:34 PM
zxguy1986's Avatar
Wait. You switched out the old sensor - hooked up the new one - and it doesn't read at the gauge - but the old one did? First thing to check: your harness connection at the new sensor. Remove, clean male/female terminals, reconnect.
Old Sep 21, 2014 | 03:25 PM
cbernone's Avatar
Think teflon tape is impeding the ground going to remove it.
Old Sep 21, 2014 | 03:30 PM
cbernone's Avatar
Old sensor seamed faulty but had teflon tape on it too.
Old Sep 22, 2014 | 11:20 AM
cbernone's Avatar
Standing ohms cold should be 300. Open should be whats?
Old Sep 22, 2014 | 09:31 PM
Zuphoria's Avatar
just ground it like rogerz said. you will know instantly if its a sender prob or gauge.
Old Sep 23, 2014 | 11:12 AM
cbernone's Avatar
Might have bought a bad sender new sender goes up one mm over 120 and stops not enough ground, taking it back to advance auto, guess all senders are the same resustance!
Old Sep 23, 2014 | 11:15 AM
cbernone's Avatar
Old sensor would go zero to 180 back to zero so know that's bad
Old Sep 23, 2014 | 07:21 PM
Zuphoria's Avatar
so whats the scoop? fixed?
Old Oct 2, 2014 | 08:20 PM
cbernone's Avatar
Cleaned up old sensor removed rust dirt reinstalled with assembly lube real tight fit good ground hoover constantly at 170 degrees problem solved. Anybody need new temp senso?
Old Oct 3, 2014 | 12:18 PM
Ascastlat's Avatar
you might need to ground it out. with some of them the sender is suppose to ground its self. but the instructions said that in some cases an addition ground is needed.
just an idea
Monkies
Sep 21, 2014 03:36 PM
Z92AL
Mar 1, 2013 10:09 PM
Turbo86
May 25, 2007 08:50 AM
emo236
Mar 28, 2004 04:05 PM
wiskman1
Apr 21, 2002 08:56 PM
