Vg30e
Old May 23, 2007 | 02:20 PM
Kidcorona's Avatar
Vg30e
I know that it depends mostly on the block's endurance, but how much power can I get out of a VG30E, without a turbo, block bore out, or a bottle? It's not that I hate turbos, just the opposite, but it doesn't have a turbo from the factory, and I want to keep it as stock as possible. The main problem with turbos is having the gauge on the support beam would be less than ideal, considering I want it to be a nice daily driver, and not for racing.
I've already been told that it won't reach 300 whp n/a, and more or less that wanting to leave it n/a is a fool's errand, but anything is better then the 160 at the crank.
This should probably moved to performance.
Old May 23, 2007 | 04:32 PM
AZ-ZBum's Avatar
With about $5k in parts, you can get around 200hp at the rear wheels without nitrous.
But if you're really interested in making power, you won't stop from going forced induction.
The only difference between a VG30E and VG30ET block is the compression ratio because of the pistons.
Old May 23, 2007 | 04:52 PM
entropy31's Avatar
The Cake Is A Lie!
that would be with a bore/stroke though right. he wants it without bore/stroke or nitrous. either way, its a lot of money for basically nothing. for what you spend to get any worthwhile gains from a vg30e, you could buy and modify a factory turbo z31.
what you want is a contradiction. more power from the vg30e, but basically stock. not gonna happen, sorry.
Old May 23, 2007 | 04:55 PM
Kidcorona's Avatar
So, I'm screwed three ways to Sunday.
Old May 23, 2007 | 04:56 PM
entropy31's Avatar
The Cake Is A Lie!
pretty much, yeah.
Old Jun 16, 2007 | 07:18 AM
MI 35th's Avatar
my suggestion is just add bolt-ons I/H/E and some high flow cats or test pipes.
It wont make the car much faster but i will give the car a better sound and if you are not happy with those gains you wont be happy with an NA car ever unless you can afford limitless R&D.
I would swap pistons and throw a new metal HG and run a 46 trim t3/4 at 10psi that should give you all the power you are looking for. That with a 3" DP and high flowing exhaust and proper fuel tuning you should easily be in the 200+ hp range.
Old Jun 17, 2007 | 10:31 AM
AZ-ZBum's Avatar
You don't need to swap pistons or use metal head gaskets to turbo an NA motor in the Z31.
http://www.redz31.com
woodlandSerenad
Jul 5, 2015 08:00 PM
shellofinsanity
FS: 300ZX (84-89)
Jun 15, 2013 03:57 PM
turbo.z85
FS: 300ZX (84-89)
May 17, 2007 04:46 PM
adamvann3
FS: 300ZX (84-89)
Dec 4, 2004 12:48 PM
pylon_boy
Feb 29, 2004 08:21 AM
