Twitchy ignition?
Twitchy ignition?
So my '85 Z31 n/a has been acting strange recently when I try to start it.
First off when it does start it's a very weak start. There's times where it's turning over the motor but wont start. and there's time where nothing happens at all but a click.
I've checked the fusable links they look fine. I got the battery/starter test done at autozone which came back as a positive.
It's really strange because it's intermittent, I almost want to say it's a bad ground somewhere, or maybe it's the ignition switch going bad? With the weather getting colder I'm worried it wont start at all once it gets down to freezing.
Any insight?
Any insight?
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
if you do the above you may solve your problem but if not then at least you will have eliminated bout 75% of the usual z31 problems. Get an interstate battery. they don't die and they last far beyond the five year warranty mark.
