turbo time... (looking for parts still)
Old Aug 3, 2007 | 01:27 AM
turbo time... *pics (looking for parts still)
my time has come, i pulled the motor on my 87 for a new oil pump and as luck would have it the driver-side manifold is cracked, so on with the turbo!! (pics coming soon)
parts i need still..
1. 87+ turbo ECU
2. turbo oil feed line
3. stock metal coolant lines
its still in the crude stages of prep, but it should be put back together as soon as i can get the parts..
Old Aug 3, 2007 | 05:45 PM
update......
Old Aug 7, 2007 | 11:23 AM
stock 88T auto oil cooler are BIG, these oil cooler designs could compete with todays more modern designs easy..
the only question is, how the hell do i hook it up?
Old Aug 7, 2007 | 11:45 AM
Looks just like the 280zxt oil cooler. They aren't all that big. Lookie at these:
Just hook it up w/ the stock lines.
Old Aug 7, 2007 | 11:56 AM
thats the problem, i had to cut the lines to get it out, but if i can get the oil filte block i could just use some braided SS line i have laying around, when i compare them i dont use size, i use the fact that a cooler with denser fins wont alow air to pass through as easily, but it seems that once again nissan did its homework when they designed it.
Old Aug 7, 2007 | 11:59 AM
WTF... you cut the lines??? Why didn't you just remove them properly by unscrewing the connections?
Old Aug 7, 2007 | 12:03 PM
because it was only the short line lines that go from the edge of fender well to the oil cooler.
Old Aug 7, 2007 | 12:21 PM
That doesn't really explain why you cut them instead of unscrewing them...
Old Aug 7, 2007 | 12:31 PM
no tools, plus you pay more at the junkyards when you call on their guys to help you..
Old Aug 7, 2007 | 08:20 PM
nismo619's Avatar
i have a 1984 300zx turbo im having to force to sell now ill sell the hole car as is its a junk parts car but the interior is completely redone for 150 dollars title in hand
Old Aug 7, 2007 | 08:26 PM
i think one experience with a parts car is enough for me..
Old Aug 7, 2007 | 11:12 PM
Las VegaZ's Avatar
I may have the ecu. And oil line. Let me check.
Old Aug 8, 2007 | 12:06 AM
im not so worried on the oil line as i am about the ECU.
Old Aug 9, 2007 | 10:27 PM
well ****, my oil seal is leaking like all living hell, but once theres oil on the bearing their is NO shaft play, only a oil leak..
Old Aug 9, 2007 | 11:02 PM
260zturbo's Avatar
Stupid Hurricanes...
might be time to rebuild the turbo
Old Aug 9, 2007 | 11:26 PM
it helps if i put the oil in the inlet instead of the outlet too, results in the morning!
Old Aug 12, 2007 | 04:49 PM
timing belt parts are ordered, plus a huge summit order, on the way..
Old Aug 12, 2007 | 05:02 PM
Goofyz's Avatar
Speaking of shaft play
are those turbos the same as the ones on the z32? i got a couple laying around that are in decent working condition
Old Aug 12, 2007 | 05:24 PM
i dont think so, i think the z32 turbo's are t25's..
Old Aug 13, 2007 | 04:38 PM
akz31's Avatar
Yep z32 has twin T25 snails
T3 FTW lol
Old Aug 13, 2007 | 04:39 PM
Originally Posted by akz31
T3 FTW lol
T3/T4 Hybrid FTW.
Old Aug 13, 2007 | 04:41 PM
Gt40 Ftw!!!!
Old Aug 13, 2007 | 06:03 PM
4' turbo inlet FTW!!
Old Aug 13, 2007 | 06:11 PM
entropy31's Avatar
The Cake Is A Lie!
BAM!!!
Old Aug 13, 2007 | 06:24 PM
but the ones i posted actually work and are not for display..
