turbo time... *pics (looking for parts still)
my time has come, i pulled the motor on my 87 for a new oil pump and as luck would have it the driver-side manifold is cracked, so on with the turbo!! (pics coming soon)
parts i need still.. 1. 87+ turbo ECU 2. turbo oil feed line 3. stock metal coolant lines its still in the crude stages of prep, but it should be put back together as soon as i can get the parts.. http://img.photobucket.com/albums/v3...x/DSC00008.jpg http://img.photobucket.com/albums/v3...x/DSC00007.jpg |
update......
stock 88T auto oil cooler are BIG, these oil cooler designs could compete with todays more modern designs easy..
the only question is, how the hell do i hook it up? http://img.photobucket.com/albums/v3...x/DSC00164.jpg http://img.photobucket.com/albums/v3...x/DSC00163.jpg |
Looks just like the 280zxt oil cooler. They aren't all that big. Lookie at these:
http://www.rallydesign.co.uk/catalog...IL_COOLERS.jpg Just hook it up w/ the stock lines. |
thats the problem, i had to cut the lines to get it out, but if i can get the oil filte block i could just use some braided SS line i have laying around, when i compare them i dont use size, i use the fact that a cooler with denser fins wont alow air to pass through as easily, but it seems that once again nissan did its homework when they designed it.
WTF... you cut the lines??? Why didn't you just remove them properly by unscrewing the connections?
because it was only the short line lines that go from the edge of fender well to the oil cooler.
no tools, plus you pay more at the junkyards when you call on their guys to help you..
i have a 1984 300zx turbo im having to force to sell now ill sell the hole car as is its a junk parts car but the interior is completely redone for 150 dollars title in hand
i think one experience with a parts car is enough for me..
I may have the ecu. And oil line. Let me check.
im not so worried on the oil line as i am about the ECU.
well shit, my oil seal is leaking like all living hell, but once theres oil on the bearing their is NO shaft play, only a oil leak..
might be time to rebuild the turbo
it helps if i put the oil in the inlet instead of the outlet too, results in the morning!
timing belt parts are ordered, plus a huge summit order, on the way..
Speaking of shaft play
are those turbos the same as the ones on the z32? i got a couple laying around that are in decent working condition
i dont think so, i think the z32 turbo's are t25's..
Yep z32 has twin T25 snails
T3 FTW lol |
Originally Posted by akz31
T3 FTW lol
Gt40 Ftw!!!!
but the ones i posted actually work and are not for display..
