Tail lights always on
Old Jun 9, 2002 | 05:57 AM
Spot's Avatar
Re: Tail lights always on
look in the drivers floorboard up near the pedals, you may find small hard plastic whitish pieces - if so then that used to be the button that depresses the brake switch which turns off your brake lights. as a temporary fix you can cover the hole with a nickel and piece of duct tape, or screw a nut/bolt into the hole. look up on the pedal (you have to lay on the floorboard like a contortionist to do this) and use a flashlight to see if it's gone. there are 2 buttons on the brake pedal - one for turning on brake lights, the other to cancel cruise when you push the brake pedal. if you have a 5-spd, there's also one on the clutch pedal for turning off the cruise if you push the clutch.
Old Jun 9, 2002 | 07:34 PM
Spot's Avatar
you can put a nut/bolt thru the holes and never have to worry about replacing them again.
or, if you're on a really tight budget.... a nickel held over the hole with a piece of duct tape works too (that was my temp fix before i found a nicely sized nut/bolt).
Old Jun 9, 2002 | 07:35 PM
Spot's Avatar
it's 'supposed' to be a little plastic button. after 15 or so years tho, it just doesnt hold up like it used to...
the new buttons are green (or at least the ones i got for my show car were).
Murph Z32
25
Oct 7, 2012 08:07 PM
kr11zzz31
Sep 8, 2011 07:39 PM
norrbr
Apr 17, 2004 10:53 PM
shall345
Sep 20, 2003 12:35 PM
Mildog
Jul 24, 2003 04:56 PM
