squeeling brakes
Old 01-24-2008, 08:57 PM
West Coast!
tonsoffun300zx's Avatar
squeeling brakes
ok so i just bought hoov's 300zx and when i went to change the brake pads i found out that the rear passengers side rotor was dead and so were both rear calipers so i went and replaced it all but now when i go to brake the same dang brake squeels. im not sure what to do i purged both brakes after i replaced them and the fluid is to the top is there something im not doing right?
tonsoffun300zx is offline
Old 01-24-2008, 08:59 PM
did you ad the no squeal brakes crap? its like a sticky spray material you put on the back of the pads before you stick them in the calipers so they dont scream at you.
snwbrderphat540 is offline
Old 01-24-2008, 09:01 PM
West Coast!
for reals? what is it called and does this mean i have to take them off again and put them back on again or can i just spray it on now as is?
Old 01-24-2008, 09:04 PM
no, could be other reasons.... but this really will happen. you put the brakes back together correctly and with new pads yes? maybe it sat a while go out and drive it use the breaks alot (dont slam them though) and try to wear off any surface rust/deterioration thats built up on them from lack of use.
Old 01-24-2008, 09:06 PM
West Coast!
ok i'll try that but the stuff you were talking about would that fix the problem if i took off my brake pads sprayed that spray and re-installed the brake pads?
Old 01-24-2008, 09:19 PM
could. but better start with the simple first. but yeah its a sticky compound that goes ont he back of the pads so when the sit in the calipers they stick to the walls better and wont move around and squeal.
explanation: http://www.aa1car.com/library/2003/bf90318.htm
the product: http://www.permatex.com/products/aut...rake_Quiet.htm
autozone will cary it or w/e place you get your parts at.
however idk if the Z31 has the anti squeal shims in it or not, if so, this prolly wont help you much
Old 01-24-2008, 10:17 PM
the rotor is fine, it just needs to be surfaced.
hoov100 is offline
Old 01-24-2008, 10:30 PM
I'm a Registered User!
SpeciallySpiked's Avatar
Yeah, when you put new pads on you should have them turn your rotors
(checker/advanced auto/etc will typically do this for free for you if you buy the pads from them)
Did you do that or just install new pads?
SpeciallySpiked is offline
Old 01-25-2008, 05:25 AM
Distinquished Guest
johnZboy's Avatar
Cool Soaked....
So, just how much did you get for this "z" that needs the engine rebuilt and a brake job?
Are we going to have to endure "bumper-to-bumper" tech sessions with the new owner until all the "little" quirks are fixed?
Are you getting finance charges on the note, as well?
Nice...
johnZboy is offline
Old 01-25-2008, 10:49 AM
Nice...
their is nothing wrong with the car mechanically except for it needed new rear pads and the rear rotors surfaced and the oil changed.
hoov100 is offline
Old 01-25-2008, 05:50 PM
West Coast!
well i already got a rotor from an 87 zxt this ones felt and looked great so i swapped them out and as for the pads i bought new ones at autozone and installed them myself.and the old rotors were far gone to much to resurface ohh and what else can i use instead of royal purple cause i can't find it anywhere
Old 01-25-2008, 07:45 PM
i would save the rotor and take it to car quest or somewhere where they surface the rotors and see if its at minimum thickness as i measured it with a caliper and it had a few more in it.
but you can only get RP in cali. at napa.
hoov100 is offline
Old 01-25-2008, 07:57 PM
Pr0n Addict
KasbeKZ's Avatar
RP is only in Cali? seriously? i know i can't find it here but i didn't think it was only in CA. that's rare sheet
KasbeKZ is offline
Old 01-25-2008, 08:23 PM
no, napa is the only carrier of RP in cali unless you go to a mom and pop shop.
hoov100 is offline
Old 01-25-2008, 08:33 PM
Queen of Yachts
z-hag's Avatar
Location: warmspott, trollville.......somewhere sailing the seas--fla, virgin islands...wherever....warm water....LOL
and if you do not use repco bimetal brake pads, you will die in a fiery ball of .........
z-hag is offline
mikebuhrZ
11-24-2008 12:29 AM
flightforlife07
02-22-2007 10:48 AM
DOC51677
11-22-2005 07:57 PM
hellraZor
05-31-2005 11:03 AM
Al Dukes
10-11-2003 01:23 PM
Quick Reply: squeeling brakes
