Replaced Differential Mount and Subframe Bushings and....
Old Oct 18, 2014 | 10:00 AM
ivyleague's Avatar
So I just got my car back from the shop after having them install the V2 differential mount and prothane subframe bushings and had them do a 4 wheel alignment and the car still clunks when pushing on the accelerator.
Where do I look next? The clunk is better and isn't noticeable when just maintaining a speed, but if I go WOT then it still clunks.
Old Oct 18, 2014 | 12:21 PM
zxguy1986's Avatar
Have you checked the u-joints on your drive shaft? They clunk when worn out. New drive shaft pretty cheap and an easy install if you have a lift.
Meanwhile, do everyone a favor. Sign in, go to User CP menu (upper left), click Edit Signature and add your Z model, year, shifter, turbo or NA, etc. Saves you having to add it to every post. (Guys here go crazy if you don't lock your Q to your specific Z every time you post...They just ignore questions without enough info) Then click Edit Avatar and you can add a little Z pic under your nick. Cool. You are solid here. Thanks.
Old Oct 18, 2014 | 08:01 PM
ivyleague's Avatar
I haven't checked u-joints yet, thanks for the tip, plus the advice about signature.
Old Oct 20, 2014 | 09:12 AM
rogerz's Avatar
Grumpy & Helpful
try shaking the exhaust system. loose or poorly installed exhaust/muffler can cause noise. happened on my son's 85T after magnaflow installed. shop made good on it and apologized.
Rupe
Jul 3, 2012 08:00 PM
Champagne
FS: 300ZX (90-96)
May 4, 2011 09:19 AM
Mrmoose
FS: 300ZX (90-96)
Feb 20, 2011 09:27 PM
bpealer
Sep 5, 2006 08:26 AM
mewfis138
Jun 11, 2005 08:34 PM
