Question for the gurus...
Guest
Posts: n/a
On the head temp sensor, what's the typical resistance or output voltage range? I get 5 volts in and 0 out when the engine's hot. That what it's supposed to be?
Or better yet, is the a better manual that covers the more technical aspects of a 86 NA engine? Hayne's book I have doesn't really get into it.
Guest
Posts: n/a
yes, the factory service manual really goes into it.
and you measure the resistance of the CHTS, not the voltage (0 volts is because both sides are then grounded)
at 212 degrees, resistance should be about 200 ohms.
at 68 degrees, resistance should be about 2000 ohms.
sticky280zx
Oct 1, 2007 01:36 PM
