Preferred oil
Old 03-26-2014, 03:27 PM
luvatenor's Avatar
Preferred oil
I just acquired a 1984 300zx with 60,000 miles. I would like to perform the best maintenance I can. What is the preferred oil and viscosity for this car with this mileage -I read that for the 350 and 370 models Pennzoil Platinum was rated tops. Any thoughts?-Thanks
luvatenor is offline
Old 03-26-2014, 04:30 PM
zxguy1986's Avatar
Welcome and congrats! Sounds like an amazing find and you can post some pics for us all soon.
You will get lots of opinions on your oil Q. With only 60K, that motor is just breaking-in still, IMHO. If it has been treated well, it can go forever.
Why not check out XenonZ31 Reference and download your factory service manual (FSM) and your owner's manual (OM). Loads of other docs there too. For a quick check, the back pages of the OM will list the Datsun/Nissan recommended motor oils (pre-synthetic, of course)... You should probably start your search there.
zxguy1986 is offline
Old 03-30-2014, 10:14 AM
Grumpy & Helpful
rogerz's Avatar
I use Mobil One (had an engineer buddy whose job was testing and designing lubrication for Mobil) in the engine. I use Redline MTF in my tranny smooths things out nicely if it is a little sticky. Diffy synthetic of the correct visosity. I have used Mobil One in every vehicle owned since 85.
rogerz is offline
Old 03-30-2014, 11:54 AM
PredatorZ's Avatar
Service History
If you are unsure of the cars service history, have the timing belt and water pump changed, also change the chts at the same time, since its a pain to get to and can go bad. there are kits from companies like Courtesy Nissan that has everything you will need for your service. The Z31 engine is an interferance motor, which means if the belt fails pistons and valves will colide with serious results.
Post some pics of your car when you can, High res if possible
PredatorZ is offline
Old 03-30-2014, 05:42 PM
Grumpy & Helpful
rogerz's Avatar
if you are really interested in the best maintenance lube types are least thing you should worry about. Predator is right. CHANGE THE TIMING BELT. here are some other things:
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
Replace outer tie rod ends, and ball joints. replace the bushings with poly (don't forget to lube them as directed unless you like squeaky things). New shocks. Get new boots for power steering. all those things will make you think you are driving a different car. doing them piece meal is a waste you won't see a great improvement until you do the complete job. You need to get the car realigned after messing with the front. Have your tires in good shape and rebalance. Rear bushings nice too but more work and you won't notice as great an improvement. Rear shocks also because if the fronts are gone so are the rears. if car squats when you jump on the gas the rears are gone. If you have the electro adjustable shocks they are DEFINITELY GONE.
If you are doing a turbo car shocks (electro adjust I think may be only on the turbos) then you need the adapter plates to fit modern shocks to the car. Easiest way is find an n/a at the junkyard and take the mounting plates. They may be available thru NAPA (listed) but I had the n/a plates.
rogerz is offline
shogunb
01-10-2013 11:25 PM
Fast240Z
10-14-2005 01:37 PM
Fast240Z
05-29-2005 07:37 AM
Quick Reply: Preferred oil
