Need to know what what color wire is behind the main AC compressor wire?
Old Jul 27, 2017 | 03:40 PM
Mojobaby27's Avatar
Have an 86 z31 and I think a rat got a hold of my power wire to the AC compressor. The wire coming from the compressor is good all the way to the plug (mine happens to be black ) but where it plugs in, on the other side of that, I see a wire that has nothing on it it looks yellow with a green stripe and possibly one Redband can someone confirm if this is the right wire to connect to. I tested it for voltage and it only gave me a .03 V rating. So I'm thinking either maybe wrong wire or I may have another problem Also. Thanks
Old Jul 28, 2017 | 04:48 AM
Mojobaby27's Avatar
Problem solved, I had access to the factory service manual, but I couldn't find AC compressor and what section it was listed under, I was looking in EL for electrical, turns out it was HA (Heating and air, duh ), and it's not called AC compressor it's called magnet clutch. But I was correct, my main question was, if it was a Y/G wire and it shows that it is on the diagram. So Admins, can marked this on as solved. I just needed a lay person's interpretation of the FSM and chapter abbreviations and help finding what AC compressor was called, luckily I was able to reason and figure it out on my own.
Old Jul 28, 2017 | 05:41 PM
86tcoupe's Avatar
Problem solved
just a note datsun ,nissan and most other jap cars ,the wiring looms were outsourced,(most were )toTaiwan , Indon, they did not get the wiring color 100% or even 90 % right
we saw 200sx's with tail light wires all G-b
Your supposed to check from pin to pin...yeah right
Old Jul 31, 2017 | 01:32 PM
Originally Posted by mojobaby27
so admins, can marked this on as solved. I just needed a lay person's interpretation of the fsm and chapter abbreviations and help finding what ac compressor was called, luckily i was able to reason and figure it out on my own.
Old May 8, 2023 | 03:09 PM
Carlos454's Avatar
what ended up being the issue? I have same problem. Thanks
mvpz
Mar 3, 2016 01:34 PM
naaaad
Nov 21, 2015 08:24 AM
aruiz714
Dec 10, 2012 10:18 AM
FubarI33t
Mar 15, 2006 08:39 PM
79280ZXT
Jun 12, 2002 03:24 PM
