I hear things,i'm not crazy
Old Mar 17, 2009 | 07:14 AM
jrealmuto1's Avatar
Question I hear things,i'm not crazy
Here's the thing. I put new brakes on front n rear. New tires after. When i start to come to a stop, without pressing the brake, i hear coming from my right rear a howl as if the brake is being pressed. Would this be the caliper ? Rotors are good. Now when i took the brakes off on the back, one was worn alot more than the other.
Old Mar 17, 2009 | 07:34 AM
And there was no howl before doing this brake job? Have you re-checked to make sure the pads are seated tight & correctly?
On the rears... do you mean the inside worn more than the outside, or left worn more than the right (or vice versa) ?
Old Mar 17, 2009 | 07:38 AM
jrealmuto1's Avatar
Didn't do it before i changed. And the pads, one pad, on the outside and inside, was worn more than the other side. its as if one side is pulling more than the other. i checked and made sure the shims,and pads were set back in right and they were. i'm just hoping its not the caliper, they're $100 each, and i'm so picky, i would replace all of them at one time. if i tap the brake while its happening, it stops and comes back.
Old Mar 17, 2009 | 07:42 AM
So one side of the car was worn more? Check all the ebrake parts to make sure both calipers are pulled & released evenly. If all that checks out, that caliper might be frozen, or one is weaker than the other (seals... air in lines... etc).
Old Mar 17, 2009 | 07:58 AM
jrealmuto1's Avatar
well on the left side, the cable was pulled from that bottom clamp where it is missing the slide in part where the cable goes into,but ill check everything at the shop this afternoon after work.thanks for the tips and help man. ill let u know what it was/is.
Old Mar 18, 2009 | 08:11 PM
jrealmuto1's Avatar
ok, everything checked out ok, but still cant find the problem. it started after i got the tires put on.. i had to replace to wheel studs today, no biggy... i also cleaned everything spotless...its very annoying. i can put it in gear, cut off the car , and rock it back and forth and still hear it...hmm i guess ill have to replace everything till it stops, ill start with rotors, then caliper, then a new car...just funny how i fix one thing than another than another...soon ill have 10k invested and in debt..
Old Mar 18, 2009 | 08:16 PM
Check the rotor surface for glazing. You might want to hit them w/ a surfacing kit.
Old Mar 18, 2009 | 08:17 PM
when was the last time you changed the fluid in your diff? did you jack up one side of the car to do the brake job or did you jack it all up at once?
Old Mar 20, 2009 | 06:10 PM
jrealmuto1's Avatar
changed all the fluids less than a month ago, when i bought the car.. and it did to turn to be the rotor....so i took the rotors off my buddys z and replaced his, to save money, i am going to take his old ones to the school and have them turn them for free...so thanks for everything !
FricFrac
Other Cars
Nov 13, 2012 06:36 AM
Mada2249
Sep 8, 2008 09:33 PM
inqui-Z-tor
Aug 7, 2007 07:54 PM
jfairladyz
Dec 5, 2005 08:33 PM
MR300ZX909
Jul 10, 2004 07:34 PM
