how do i get air bubbles out of my vg30e ?? it has no bleed valve
Old Jul 15, 2011 | 10:22 PM
nvmy300's Avatar
Question how do i get air bubbles out of my vg30e ?? it has no bleed valve
my z31 is getting hot since i flushed the radiator so i am thinking its a air pocket i have no thermostat i took it out .i looked for the bleed valve and it don't have 1 so how do i get the air out ?????
Attached Thumbnails how do i get air bubbles out of my vg30e ?? it has no bleed valve-h-40-.jpg
Old Jul 15, 2011 | 10:34 PM
Welcome to ZDriver.
Put the thermostat back in.
Old Jul 15, 2011 | 10:38 PM
nvmy300's Avatar
i live in Darwin its allays hot and i was told to take it out ????
Old Jul 15, 2011 | 10:41 PM
Was it overheating before you flushed the radiator & took out the thermostat?
Old Jul 15, 2011 | 10:43 PM
nvmy300's Avatar
it started wen i flushed it out .then i took the thermo out and made no difference
Old Jul 15, 2011 | 10:46 PM
nvmy300's Avatar
i took the thermo out 3 days after flushing it
Old Jul 15, 2011 | 10:47 PM
Have you checked the coolant level since it got hot?
Old Jul 15, 2011 | 10:51 PM
nvmy300's Avatar
yes it need a little wen you check it but not much .and if you turn it of and back on it drops quick and i read on a forum that its the sign's of air pockets in the motor .cos before i flushed it there was no problems
Old Jul 15, 2011 | 10:57 PM
Since air rises in water, they will RISE to the top of the radiator fill point too. You can leave the radiator cap off, and see a rush of coolant when your thermostat opens (well... you can't because you removed yours).
Lets cut to the chase... leave the rad cap off & let the car idle to running temp. That will get all the air up to the top. Then get an infrared thermometer (go buy one if you don't have one) and take a reading at the thermostat housing, then again at the radiator OUT hose. There should be a 25-30*F temp drop. If not, your radiator isn't doing it's job.
And freaking put the thermostat back in.
Old Jul 16, 2011 | 09:33 AM
AZ-ZBum's Avatar
NEVER listen to that person again for any car advice ever. Person is obviously an idiot when it comes to cars.
NismoPick got it right on burping the system.
Old Jul 16, 2011 | 12:10 PM
HexaggramJDM's Avatar
yea man, Automotive engineers dont just create a motor with extra parts for fun. everything has its purpose.
woodlandSerenad
Jul 5, 2015 08:00 PM
ddatsun
Nov 12, 2007 12:44 PM
austinrobert
May 14, 2006 11:06 AM
dhizzy
Aug 19, 2002 09:05 PM
stickben
Apr 4, 2001 08:12 AM
