Help, Car cranks but won't fire
Old Apr 28, 2026 | 08:16 AM
magikal55's Avatar
Hello all, my second post here. I have figured out the wiring harness and wired in new plugs for the fuel injectors. I am using the cheap Chinese new-type fuel injectors instead of OEM. I have a '91 Nissan NA 2+2 300zx. The car will crank but will not fire/combust. I also replaced the ignition coils. When I first got the car it ran on starter fluid and stalled after 5 miles at a stop. I am about to hook up a OSBD1 cable to check the error codes with ECULink. One big thing I noticed is fuel is not entering the fuel rail, it stops right past the fuel filter and will not go up into the fuel rail and to the injectors. I pulled the pipes later on down the fuel rail from the filter and they are bone dry, no liquid. The fuel pump was replaced and that is how I got the vehicle to run on starter. Any suggestions on what to do next? Anything I should check for with ECULink? I am considering rewiring the harness and putting OEM fuel injectors in, which will be $600 or check the physical ECU for damage, leaking capacitators.
Thanks all.
Old Apr 29, 2026 | 06:34 AM
JimLev's Avatar
Have you checked the fuel pressure?
Old Apr 29, 2026 | 10:07 AM
Great White Zed's Avatar
+1
Are the plugs firing?
andyb
Jun 2, 2021 11:12 AM
CrispyZ
Jul 20, 2020 01:09 AM
armanzz
Nov 22, 2011 11:32 AM
rgus30
Aug 24, 2006 02:45 PM
nismo619
Feb 27, 2006 07:40 PM
