heater blowers have a mind of their own...
Old Oct 12, 2013 | 01:16 AM
reefer24131's Avatar
I have a 1988 z31 manual turbo uk spec. I put my heaters on yesterday and they cut out and then came back on and they were surging if that makes sense. it seemed like a bad earth so I pulled the plugs cleaned them and also cleaned the plug on the blower motor. I still have this problem. when it cuts out I have to slide the **** to 'off' and then back across to high and they will come back on.
im assuming the heater control panel/box is knackered can anyone confirm this?
thanks.
Old Oct 14, 2013 | 09:15 PM
AZ-ZBum's Avatar
I would suspect vacuum leaks first.
Old Oct 15, 2013 | 03:48 AM
thanks for the reply.
so is it all vacuum controlled? I see the multi plug on the back of the heater control panel and assumed it would operate the fan blower speed by adjusting the voltage? where will I find the vacuum pipes, will the be under the dash or under the hood?
thanks.
Old Oct 26, 2013 | 05:06 PM
AZ-ZBum's Avatar
The blower motor speed is electronically controlled, but all the flaps are vacuum operated.
The lone vacuum line originates at the vacuum pump/tank at the front right of the car. At least, I believe it will still be front right even for you over there...
vrocious
Jun 9, 2008 07:09 AM
FubarI33t
Jan 17, 2008 03:59 PM
snwbrderphat540
Jun 1, 2007 09:41 PM
theramz
Mar 28, 2003 06:52 PM
corvette
Sep 8, 2002 09:32 PM
