Head lights going up & down
Old Jul 31, 2014 | 02:28 PM
Donn144's Avatar
on my 84AE, when I turn the head lights on, they continuously go up & down.
Do I have a blown fuse somewhere or a bad relay?
Thx
Old Jul 31, 2014 | 03:36 PM
zxguy1986's Avatar
Guess: Fouled contacts in light stick on steering column. Videos available for cleaning/replacing the stick. YouTube, I think they were.
Old Jul 31, 2014 | 03:47 PM
rogerz's Avatar
Grumpy & Helpful
that is a fairly complicated circuit involving some limit switches so it may not just be cleaning the switch. Take the schematic from the FSM down to kinkos and have them blow it up to 11x17. Much easier to read unless you are a keen eyed twentysomething.
As I'm feeling generous today I won't make you go look.
Old Jul 31, 2014 | 04:33 PM
Donn144's Avatar
I do not know if this is the issue...I replaced the digital dash and had to pull the entire dash.
I do not know if this problem was existent before I pulled the dash. car has been pretty much parked for a while. I checked the fuses and they look good. Also checked one relay and it checks out.
Perhaps when I put the steering wheel back together, I missed something..I do not think I did..when I use the switch to turn the head lights up, they remain up. But when I use the left blinker switch to turn on the lights..they do not go on..neither do the side marker. Flashers work.
Any suggestions?
Old Jul 31, 2014 | 05:54 PM
Donn144's Avatar
Problem was the cable was not all the way in..so I seated it in the connecter and "Let there be light! All good!
Old Jul 31, 2014 | 06:41 PM
Donn144's Avatar
But to all interested; the symptom of the cable not being fully seated is:
Head lights pop up and down repeatedly. When the lights go up using the switch, they do not turn on..nor do the side markers.
Interesting!
runningjalapeno
Sep 29, 2007 06:29 PM
Comrade_Charlie
Feb 23, 2007 07:30 PM
skupy
Feb 9, 2005 02:24 PM
dr. buddha
Apr 22, 2004 09:43 AM
judygillispie
Sep 7, 2002 10:21 PM
