head lights
Old Sep 13, 2007 | 06:42 AM
runningjalapeno's Avatar
head lights
hello I did the search on the website could not find anything, has anyone ever connect the head lights on the same connection? my left headlight is very dim the right works very well so I wanted to run the wires from the right light to the left light,I just need to pass my car inspection any information will help.
Old Sep 13, 2007 | 06:51 AM
use a relay and wire them in that way. use the wire from one headlight to trigger the relay. fix it properly once, and never do it again. the relay usually comes with instuctions, so read them and it will work great!
Old Sep 13, 2007 | 06:58 AM
headlights
Do I just buy the relay at autozone or standard auto parts? Will one relay work for the low and high lights?
Old Sep 13, 2007 | 07:18 AM
I made this thread for a reason https://www.zdriver.com/forums/showt...ght=headlights
Old Sep 19, 2007 | 12:33 AM
Heat Rave R's Avatar
It isn't clear if you used just one relay for both sides, or if a relay is needed for each side and/or low beam + high beam (two to four relays, total). So does this mean you're bypassing the underhood headlight relay, or is the underhood relay just being used to activate the new aftermarket relay?
Old Sep 19, 2007 | 10:21 AM
I didn't do anything w/ the relays (stock setup has 2 relays). The headlight switch connectors were the problem.
Old Sep 21, 2007 | 01:28 AM
So if you put the relay at the switch connector, specifically what wire (color?) did you put it inline with, and where did you tap for power off of? I examined my headlight switch connection, and there is no fried or blackened connection, so I wonder if something else is the cause of my intermittently dim left headlight.
Old Sep 29, 2007 | 06:29 PM
palladin21's Avatar
headlight dim
I have no idea what to do. I just bought one and drove it down from CHI. Half way down it went from dim to bright. Unfortunately it's dim again. I don't think the solution is to bypass the relays on the right fender. However there may be corrosion between there and the headlight. If you figure it out, please let me know and I'll try it too. Gary
palladin21@yahoo.com
Donn144
Jul 31, 2014 06:41 PM
Comrade_Charlie
Feb 23, 2007 07:30 PM
skupy
Feb 9, 2005 02:24 PM
dr. buddha
Apr 22, 2004 09:43 AM
judygillispie
Sep 7, 2002 10:21 PM
