fuel injectors not firing.......
Old Jun 18, 2007 | 05:31 PM
cliftcrawford's Avatar
I have an 86 300zx na, manual. My car was running, I put it up on ramps and bam! it died and has not run since. Ive had my distributer/ign mod tested, my pump works, there is fuel to the rails. I can get my injectors to fire if i ground them manually and the car runs momentarily. My question is other than the ecu, ign module, fuel pump, is there anything else that would prevent the injectors from firing? The tps, chts, ??? My ecu codes from troubleshooting are 13(ive ordered a chts and harness), 21 (coil has been changed, power transistor changed, dizzy is rebuilt, my plug wires and distr cap are new), a 31. Any ideas? thanks...
Old Jun 22, 2007 | 01:07 PM
AZ-ZBum's Avatar
crank angle sensor in the distributor
Old Jun 23, 2007 | 02:29 PM
Here's what I know:
Ive got a rebuilt distributor installed
Ive changed ecu's
Ive got fuel going into the rail and coming out
If I turn the key on and rotate the distr, I can hear each injector click.
I hear the fuel pump turn on when I turn on the key.
Anything else I can try?
TeamRonin
Oct 6, 2009 10:24 PM
scorpionp54
Jul 24, 2009 01:13 PM
280zinkansas
Apr 27, 2004 10:26 AM
NwZXlover
Jul 29, 2003 10:37 AM
NwZXlover
Jul 28, 2003 08:52 PM
