rev lmited at 2000 rpm? ?
Old Jun 29, 2007 | 10:57 AM
godzilla_753's Avatar
ive got a 85 300zx n/a
no mods. when i start the car, it idles fine, but when i try to rev it up a little,
it starts bouncing at 2000 rpm like its rev limited
im leaning towards maf,
anyone have any ideas?
btw i changed the spark plugs rotor and cap
Old Jun 29, 2007 | 11:03 AM
naviathan's Avatar
Washed it recently? Could be moisture in the TPS.
Old Jun 29, 2007 | 11:11 AM
your MAS is unplugged
(mass airflow sensor)
Old Jun 29, 2007 | 01:16 PM
is it really?
lol, ill go check
Old Jun 29, 2007 | 01:19 PM
nope its plugged in, could it be bad?
also, after the mas is plugged in, where does that plug go?
into the harness, or is there another connection between the mas plug, and the computer
Old Jun 29, 2007 | 02:21 PM
I believe it goes into the harness and right to the ECU.
but I would guess your MAS is bad. Do you know anyone that has a running 300ZX you can swap the sensor just to check?
also, don't forget what was already said about the TPS. check the plug that is on the Throttle Position Sensor. If its wet at all then dry it out good or just leave it unplugged for a few hours so it can dry.
Old Jun 29, 2007 | 03:09 PM
hmm i c, no i dont think its my tps, i havent washed it in a while
im gonna go look for another mas
could it be anything else?
Old Jul 1, 2007 | 09:12 AM
AZ-ZBum's Avatar
nope. that's pretty much the usual culprit.
Old Jul 3, 2007 | 04:11 PM
speedking1221's Avatar
hey im new here but im haveing the same problem. the conputer in my 86 300zx non t sead it was the mas .
Old Jul 9, 2007 | 07:26 PM
its the mass airflow sensor
it was the mass airflow sensoron. my car its runing fine now.
FranksZ31's
Jan 26, 2014 12:29 PM
morbidrazor
Jun 5, 2011 09:17 PM
NismoPick
Other Cars
35
Apr 10, 2008 11:21 AM
jeffs2fast
Apr 13, 2005 06:38 PM
modified300zxt
Oct 6, 2002 10:50 PM
