Fixing 86 300zx
Old Jan 2, 2018 | 09:45 PM
ProjectZ31's Avatar
Fixing 86 300zx
I am going to buy a 1986 300zx turbo t top for 500. A friend is selling and can help weld and paint. It has some things to fix from sitting outside for a while. The owner said the car needs a valve job and timing belt. I am not well versed in fixing engines and wanted some expertise to fix it properly. I have been told that a shop will probably need to do head work as well. I was not sure the process of what I need to do, thank you!
Old Jan 3, 2018 | 03:04 PM
86tcoupe's Avatar
Have any pics?
there could be quite a bit it needs checking compression ,carefully would be a good 1st step manual trans ? How many miles?
Old Jan 3, 2018 | 06:41 PM
ProjectZ31's Avatar
Not sure about miles but it has a manual transmission.
Old Jan 11, 2018 | 02:37 PM
zxguy1986's Avatar
Actual mileage at this point in time could be very important information. (smiley here) 5-speed turbo a good deal for $500 if running or almost running. You will want to 'restore' stuff in any case so check out Car-Part.com--Used Auto Parts Market for recyclers and vehicles available and near you. Make sure you have the bucks/credit available because you will need it, most likely. Great project, spectacular Z year.
Timing belt a must-do, first thing. Should have a pro do that. Major engine work needs a pro, too. Find a thinking mechanic with a good reputation, fair prices. Good Luck!
hoov100
Mar 18, 2006 09:42 AM
junk280z
Feb 14, 2006 12:48 PM
Fast240Z
May 13, 2005 11:04 AM
Cardoo
Jul 8, 2002 02:37 PM
Yuichi
May 6, 2001 06:53 AM
