female voice??
Guest
Posts: n/a
female voice??
I've heard of some z31's having a sexy female voice that warns you when your lights are on, doors open, etc.. my question to you all is, is this true? if so did it come factory on some models, or where can I get it? Any answers you can help me with would be greatly appreciated.
Guest
Posts: n/a
Re: female voice??
Yes, all 1984-1986 300ZX models sold in the US had a voice warning system. Only the SF model (sold in Canada) did not have it. Most often, the voice no longer works because the aftermarket stereo was installed improperly and they bypassed the original voice unit. The voice unit is located above and behind the ECU in the passenger side kick panel. The sound ONLY comes out the front driver side speaker. To reactivate a bypassed voice, run the left front speaker wire to the two voice unit inputs. Then run the two outputs to the front left speaker.
When the voice is activated, the voice unit cuts the signal from the stereo and inserts it's own sound to the speaker.
The ONLY things it says are:
Left door is open.
Right door is open.
Parking break is on.
Lights are on. (saved me more than once)
Fuel level is low. (my favorite, and no, it doesn't continuously blab it. just 2 or 3 times)
Guest
Posts: n/a
Re: Voice Warning System
Originally posted by Mandilater
You forgot she says rear hatch open...
I found out all these when I was jumping my car one time it just started talking scared the **** outa me.
Guest
Posts: n/a
You only need to worry when...
I think you will only need to worry when it starts to insult you and then talk continuously about irrelevant crap, wait, sorry about that.
About the hatch being open, I am not quite sure about that, however if you do not close your hatch all the way, the force of the air should push it close.
Guest
Posts: n/a
Re: You only need to worry when...
Guest
Posts: n/a
ok; so i've read all this and what you are saying is that i have a female voice in my Z just waiting to be let loose? and all i need to do is run four wires from my driver's door speaker(in the door) to some wiring that is under the dash on the passenger's side? one post said its two input and two output...how do i connect them to the speaker? that part i don't understand. and again, what wires do i look for under the dash? or are they behind the stereo?
thanks for the posts so far, and i hope someone can straighten it all out for me.
wait wait wait...just read AZ's psot again...AZ...i need to run two inputs from the STEREO into the female voice somewhere behind the ECU, which is in the passenger dash, and then output THOSE to the speaker?
Crash
Crash
Guest
Posts: n/a
Re: a female in my z???
Crash
Crash
Guest
Posts: n/a
cool...so how will i know what i am looking for? and where exactly will i find those two wires to run from the stereo to the female voice box?
thanks
thanks
Where are the wires? Uhh.... they come out of the stereo. Use the wires for the front left speaker and run them to the input for the voice box. Then, from the voice box, grab the two output wires and run them to the speaker in the driver's side door.
Guest
Posts: n/a
Crash
Crash
I once dated a Fench guy. They are very indecisive in matters of meeting girls. But cheers! equality gives you a unique chance to get to know the man you like on your own. And the brain brought up by the feminist mother does not perceive this as something out of the ordinary, the girls have the same rights to the first step. So if they don't text https://datehookup.dating/singles-tx-fort_worth-5.htm me first, no problems, I can do it myself
AZ-ZBum
300ZX Z31 Tech Tips
37
Feb 11, 2006 01:36 AM
Cw2435
Apr 30, 2003 02:40 PM
