which driveshaft
Old Nov 15, 2012 | 03:41 PM
dizzyprice's Avatar
which driveshaft
hey so i bought what i thought was a n/a 1987 300zx tranny with no driveshaft..because im swapping the busted borg warner with the nissan tranny....the problem im running into is the driveshaft i bought, thespline dont match up... its as if the splin is too small but not by much...any suggestions??
Old Nov 15, 2012 | 05:20 PM
Welcome to ZDriver!
The BW T5 and Nissan transmissions have different output shafts. Use a drive shaft meant for the FS5W71C (Z31 n/a transmission).
Old Nov 16, 2012 | 12:45 PM
reddzx's Avatar
you will need a 87-89 NA 2 seater driveshaft unless you want to change the differential flange.
84-86 diff flange is different than 87-89. Any 84-89 NA driveshaft will work with the proper matched diff flange.
Old Nov 17, 2012 | 11:10 AM
AZ-ZBum's Avatar
Nope. He will need the 84-86 NA 2 seater driveshaft. If he had the BW, then he has an 84-86 turbo (two seater).
Old Nov 21, 2012 | 08:20 PM
dizzyprice's Avatar
hey um well its a 87 tranny im putting in an taking out the borg warner
Old Nov 24, 2012 | 04:40 PM
AZ-ZBum's Avatar
*sigh*
You have an 84-86 turbo, right? This means you have an 84-86 companion flange on the differential. Unless you want the added expense of the 87-89 companion flange, get the 84-86 NA 2 seater driveshaft.
ZBUM's Z31 Transmission Information Page
http://z31.com/wiki/doku.php?id=information:driveshafts
burble_boy
Jan 19, 2021 07:52 AM
XGames415
Feb 5, 2006 01:18 PM
UltimateZ
Jun 23, 2005 12:42 PM
domsgarage
Dec 4, 2004 06:03 AM
domsgarage
19
Jan 31, 2004 08:54 PM
