which driveshaft
hey so i bought what i thought was a n/a 1987 300zx tranny with no driveshaft..because im swapping the busted borg warner with the nissan tranny....the problem im running into is the driveshaft i bought, thespline dont match up... its as if the splin is too small but not by much...any suggestions??
Welcome to ZDriver! :006:
The BW T5 and Nissan transmissions have different output shafts. Use a drive shaft meant for the FS5W71C (Z31 n/a transmission). |
you will need a 87-89 NA 2 seater driveshaft unless you want to change the differential flange.
84-86 diff flange is different than 87-89. Any 84-89 NA driveshaft will work with the proper matched diff flange. |
Nope. He will need the 84-86 NA 2 seater driveshaft. If he had the BW, then he has an 84-86 turbo (two seater).
hey um well its a 87 tranny im putting in an taking out the borg warner
*sigh*
You have an 84-86 turbo, right? This means you have an 84-86 companion flange on the differential. Unless you want the added expense of the 87-89 companion flange, get the 84-86 NA 2 seater driveshaft. ZBUM's Z31 Transmission Information Page http://z31.com/wiki/doku.php?id=information:driveshafts |
