Dash and accessories don't work until engine revved
Old Aug 15, 2021 | 08:47 AM
Gearhead63's Avatar
I just bought an 87T and am sorting through a number of electrical issues. The current one I am addressing is that when I put the key in, turn it to 'on' or 'ignition', I none of the electrical work- no lights, horn, wipers, digital dash, nothing. It will start and run. Nothing else works until I rev the engine and then the dash lights up and all the other systems mentioned now work and stay on, even when the engine goes back to idle.
I checked voltage at the battery (supposedly new) while car is off and am getting high 12s. When I start the engine and rev it, the voltage stays the same, maybe even dips with increasing rpm. So I know I have a week charging system (new alternator on order).
I put the battery on a charger overnight to make sure it's at full strength but it has not resolved the symptom. I am looking at the fsm electrical and looking for a relay that might be suspect. Fusible links are all good.
Anything else I should be looking at?
Thanks!
Old Aug 22, 2021 | 03:30 PM
Gearhead63's Avatar
Update. I have installed a new alternator and it is still not charging. Now none of the dash comes on even whe n the engine revs. Voltage regulator?
Old Aug 22, 2021 | 07:33 PM
Gearhead63's Avatar
Battery fusible link was the culprit. It did not appear to be blown but for whatever reason, it tested with zero continuity. I jumped it and the dash lights up as they should, accessories work and the alternator charges properly. Weird.
Old Aug 23, 2021 | 04:36 AM
curtisr's Avatar
My first thought would have been cleaning the grounds but glad you got it sorted.
blockmaster
Nov 7, 2013 02:30 PM
dat280
May 12, 2012 10:19 AM
weykool
Nov 17, 2010 11:39 AM
duckyz
Oct 29, 2002 06:32 PM
