Crank timing sprocket removal, please help
Old Jul 31, 2014 | 06:23 PM
AtvJim's Avatar
Hello and thanks for all your input on this forum.
I have 1985 300zx na 2+2
I will be drilling and tapping and then pulling the crank timing sprocket.
2 questions....
Do I pull the sprocket over the woodruff key or pull the woodruff key first?
After I drill and tap the crank sprocket can I reuse it?
THANKS!
Jim
Old Jul 31, 2014 | 07:33 PM
Skully's Avatar
You pull it over the woodruff key, you can't remove the key unless its showing more than half. I would use a new sprocket for sure. Soak it in penetrant or something for a while first, easier to remove.
Old Aug 3, 2014 | 04:28 AM
AtvJim's Avatar
Thank-you
Cap
Jun 18, 2012 07:58 PM
daPud
Aug 11, 2011 11:12 AM
scoobydoo512
Mar 25, 2011 12:54 PM
Fast240Z
Jul 20, 2005 02:53 AM
aceshigh009
Aug 24, 2003 12:22 PM
