Which Control Arms?
Old Mar 27, 2002 | 10:40 AM
Spot's Avatar
Re: Which Control Arms?
any of them will fit on your '85. 87+ ones are slightly longer though, which will give your car a slightly wider track. the linkage for sway bar and control arms is different too. you can use your old sway bar linkage, but I don't remember if you can use the newer style tension rods in your early z. If you have access to an 87+ then make a comparison and you'll know for sure.
Old Mar 27, 2002 | 10:00 PM
ZenArcher's Avatar
I just noticed today that the top of my left my tire (stock size) is rubbing lightly against the strut housing. Think if I installed 87+ control arms it would solve that?
ZenArcher
Old Mar 28, 2002 | 08:45 AM
Spot's Avatar
it *might* but you probably ought to find out what's causing to do this.... have you changed anything in the front lately?
mikeatrpi
Aug 27, 2012 06:59 AM
dreamz90tt
May 26, 2009 03:06 PM
jaffi
FS: 300ZX (90-96)
Jun 15, 2006 06:31 PM
73_240z
Sep 13, 2004 04:51 PM
Spudz
Mar 22, 2003 08:04 PM
