Climate controll.
Old Oct 19, 2014 | 07:21 AM
Darcy Bekkema's Avatar
Climate controll.
Have an 86 Gll turbo. Replaced all the vacuum lines going to the vacuum canister. Replaced the water cork because it was sticking. Ran the self diagnostic test and everything worked. The problem I'm having is the water cork one gets vacuum during the test. So there is no real change in vent temperature. PO gutted the ac system, that might be my problem. Is there a way to trick the climate control to believe it still have AC?
Old Oct 19, 2014 | 01:32 PM
rogerz's Avatar
Grumpy & Helpful
doubt your water control valve is sticking it is just a very simple butterfly valve. I have similar problem. during the summer I just run vacuum direct to the water valve and then reconnect in winter when heat may actually be needed. a solution I am going to try is to run 12v to the solenoid on the vac tank so you always get no heat because vac is at the valve. I'm going to send the 12v via the old switch for the headlight washer so I can turn it off and get heat in the winter.
BrettjOR
May 8, 2013 08:45 AM
friend_of_fast
Jan 20, 2007 09:38 AM
mattduskater
Apr 19, 2005 01:36 PM
paulquenet
Dec 8, 2004 03:50 PM
rupert42
Jul 27, 2004 09:10 AM
