89 NA Injectors 1-3-5 Wired Together
Old May 13, 2010 | 11:07 AM
w4tja's Avatar
While looking for another problem, I have found that the fuel injectors (1_3_5)are wired to one pair of wires, the red and Blue w/ red dots, coming from the ECU. Havent looked at the other side of the engine. But how can this run like this. The cars runs OK but should I try to reconnect then as shown in the manual. The pair that is connected to the injectors is, according to the manual, is for the #3 cylinder. Am I losing it or what?? Did someone install new injectors and wire them to only one lead from the ECU. Any ideas would be helpful.
Old May 13, 2010 | 02:27 PM
Sounds like it had the Nissan injector recall done? Read this: http://www.az-zbum.com/information.i...r.recall.shtml
Old May 13, 2010 | 02:57 PM
w4tja's Avatar
Smile Question Answered
Hey, I am not losing it. A Big Thank You to NismoPick. You certainly know your Nissan's. My 89 is wired exactly as shown in the URL you provided. I would never have found that without your help. Now back to the original problem, now where was I. Thanks A Million, Tom in Alabama
Old May 13, 2010 | 09:49 PM
w00t! What was your other prob?
Old May 14, 2010 | 07:42 PM
w4tja's Avatar
The original problem was and maybe still is, that the engine would stumble or act like it wasn't getting enough fuel at speeds over 40mph. This seemed to be more a problem after the engine heated up. Once I drove about 50 miles and stopped to refuel and got back in and the car refused to crank. It would turn over fine but not even try to fire. I had the car towed home and the next moring it cranked right up. I checked fuel pressure, replace the fuel filter, tried another distributor, tried another ECU, looked for loose connections to the fuel pump, checked the relays, fuel and that reverse polarity one, out by the battery. I am still afraid to venture off too far as I still haven't found a definite bad part.
Old May 15, 2010 | 01:35 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
This sounds a little like a problem I had. Except it was over a certain % of throttle, say 30%? Needless to say I was not getting spark because there was coolant in my cylinders.
thetremendousti
Aug 14, 2008 09:42 PM
raythenegr0
Jun 6, 2008 09:29 AM
HybridS130
May 7, 2005 10:40 AM
CWHammer
Sep 22, 2004 09:56 PM
NISMO LMR
14
Jan 21, 2004 11:50 PM
