'88 Door Issues
Old Dec 22, 2013 | 10:51 AM
ol55's Avatar
'88 Door Issues
I removed the door panel to address three issues; The door won't open, the window won't go up or down without assist, and the speaker sounds lousy.
Questions:
The door handle rod was not in the white plastic piece (the handle slide had been replaced earlier). When I went to put it in place the plastic broke. Is there a better fix for this?
The window regulator teeth look ok. Is the only solution to this to replace the regulator and or the motor? One or both? Cheapest and/or easiest way?
Not a question, but I may need a replacement speaker #.
Thanks, Larry
Old Dec 22, 2013 | 11:04 AM
rogerz's Avatar
Grumpy & Helpful
you can see if the dealer has parts. try the junkyard. window maybe dragging on the rubber that seals at the top. when I had a window replaced at a glass place the guy sprayed some magic fluid on the glass that made it operate closer to normal. Is it still slow with panel off? You might try jumping 12 volt straight to the motor and see if you have a low voltage issue. the window switches in the arm rests get tired. there is like a flat spring inside that doesn't make full contact sometimes. I had to bend it to make good contact. I just replaced my driver door panel and it made that window go down slow - okay on the way up. Just replace the speaker if the original with paper cone may be blown out. Replace both not just one. Or maybe you just need a unit made in this century. since you have the panel off you should be able to watch the mechanism work and determine if there are some tight spots.
Old Dec 22, 2013 | 02:17 PM
ol55's Avatar
Drilled some small holes and added wire ties to keep the rod in place. Works for now!
Old Dec 22, 2013 | 06:07 PM
ol55's Avatar
Thanks RogerZ. Thinking it is the PW motor. The motor sounds strong but you hear teeth slipping. I have a local guy with a Z32 (92) motor and wondering if it will fit.
Larry
Old Dec 31, 2013 | 07:28 AM
reddzx's Avatar
Z32 motor won't fit. replace the motor with a Z31 .
Old Jan 1, 2014 | 07:39 PM
ol55's Avatar
Thanks! Are all Z31 years PW motors the same? How about 2+2's?
Larry
Old Jan 2, 2014 | 05:45 AM
reddzx's Avatar
All Z31 exterior mirrors are interchangeable. However, some are heated and some are not but they will still interchange. There will just be one wire/plug left unconnected
Old Jan 2, 2014 | 05:00 PM
ol55's Avatar
Thanks reddzx. Are the power window motors also interchangable?
Old Jan 3, 2014 | 05:10 AM
reddzx's Avatar
Yes, all 84-89 window motors are interchangeable but there is left and right motors. 2+2 motors and window mechanisms are also the same.
Old Jan 3, 2014 | 03:46 PM
ol55's Avatar
Thanks again reddzx!
Old Jan 15, 2014 | 06:51 PM
ol55's Avatar
My new used motor & regulator came today from Steve (the red Z in the classifieds) -Thanks Steve!
I plan on using lithium grease where I can. Is there any reason why NOT to put grease on the regulator gear teeth and flat surface? Both this one and my old did not have grease there and I wonder why. On both you can see where it has been metal to metal in between the teeth.
Any good lube for the window channel?
Thanks, Larry
Old Jan 18, 2014 | 12:23 AM
AZ-ZBum's Avatar
That's not a factory speaker anyway.
Mike Phillips
Oct 1, 2021 12:34 PM
DeathByNissan55
Dec 13, 2020 03:42 AM
oldmanrodz
Feb 15, 2013 12:17 PM
pete8717
Feb 13, 2006 05:05 AM
