86 300zx turbo injector question
Old Aug 23, 2010 | 11:15 PM
86_VG30ET_Z31's Avatar
I have a 86 300zx turbo with dual side feed injectors an two injectors have gone bad from the connectors an a friend of mine gave me a set of six top feed injectors from a 84 300zx turbo just wanted to know if i needed to change anything to get them to work or do i just drop them i know you have to shave a little of the manifold to have them sit right plz any help would be apriciated.
Old Aug 24, 2010 | 01:46 AM
Welcome to Zdriver man. Since you own a Z31 ('84-'89 300zx). You need to go to that section. To get the help you need. This is the Z32 forum ('90-'96 300zx). Hope that helped you out. Good luck.
Old Aug 24, 2010 | 11:55 AM
I have a 86 300zx turbo with dual side feed injectors an two injectors have gone bad from the connectors an a friend of mine gave me a set of six top feed injectors from a 84 300zx turbo just wanted to know if i needed to change anything to get them to work or do i just drop them i know you have to shave a little of the manifold to have them sit right plz any help would be apriciated. From what i have read the 84 an 86 turbo cars had low impedance injectors what else should i change or is it just pluggin them in
Old Aug 24, 2010 | 06:34 PM
Top feed & side feed use different fuel rails. You will need to use top feed fuel rails with top feed injectors.
Old Aug 24, 2010 | 08:42 PM
i have a set of top feed rails an injectors from a 84 turbo do i just swap them in no other thing needed
Old Aug 27, 2010 | 09:19 PM
domsgarage's Avatar
Tough Guy
the injectors were recalled in the 84-89 z's. (im pretty sure it was all of them) look it up, get them for free.
Pashendale
Jul 29, 2013 07:55 PM
scoobydoo512
Nov 15, 2010 03:19 AM
DJAngelicon
Mar 14, 2010 07:55 AM
skittle
Feb 13, 2007 02:54 PM
zbuilder
Jul 3, 2002 03:56 PM
